I'm in the early stages of an embedded project using the nios2 cyclone, and I'd love to use the Microtronix uCLinux distro with it. However, in looking through the driver code, I'm a little confused as to the workings of the TCP/IP subsystem. Namely, I've seen mention of the 'Plugs' embedded TCP/IP ss. I specifically do NOT want to use Plugs for this project. So, two questions: does the Microtronix distro use Plugs, and, if so, can this be changed to use the standard *NIX TCP subsystem?
Any help would be appreciated, Ryan W. FrenzLink Copied
The Microtronix Nios II Linux Distribution uses the standard Linux networking code.
Dennis Scott Microtronix Datacom Ltd.
