assembly prog
Hi
Has anyone tried to write assembly language programs for nios II processor? If so plz tell me how to start the program i.e., i mean to say are any initial statements required like main() in c-lang. I wrote a sample program as follows but the error is that " %g0 not a valid register" , "%g1 not a valid register".
.text
MOVI %g0,9
MOV %g1,%g0
NOP
So someone please tell me how to overcome the problem
Hi rakesh,
You can find example assemble code in u-boot:
-cpu/nios2/start.S
-cpu/nios2/exceptions.S
-lib_nios2/cache.S
--Scott
you are writing NiosI asm for NiosII cpu ...
here's something:
    .file    "Main.s"     .section    .text     .align    3     .global    main     .type    main, @function main:     //sp <- sp -8     addi    sp, sp, -8     //ra -> *(sp +4)         stw  ra,4(sp)           // fp -> *(sp)  stw  fp,0(sp)      // fp -> sp     mov  fp,sp         aaa:    //#define LED_BASE 0x00000820     movhi    r13, %hiadj(0x00000820)     addi    r13, r13, %lo(0x00000820)          //valeur par bit (1) allume  (0) eteint     movhi    r12, %hiadj(255)     addi    r12, r12, %lo(255)          //allume led     stwio    r12, 0(r13)          call    delay1 ....
Thankyou smcnutt and slvn. I will be in touch with both of you if i have any more doubts.
rakesh,
if you need more details about assembly and instruction. you should refer to reference and developper handbooks for Nios II.
about the prog I did, it&#39;s just stupid and incomplete showing you what it looks like. (you were using Nios I assembly in your post I guess).
If your SPOC has some leds you can replace Base Led by the address where are mapped your leds, and try something like turning the led on/off
file "Main.s" .section .text .align 3 .global main .type main, @function main:     //#define LED_BASE 0x00000820 movhi r13, %hiadj(0x00000820) addi r13, r13, %lo(0x00000820) //valeur par bit (1) allume  (0) eteint movhi r12, %hiadj(255) addi r12, r12, %lo(255) //turn led on stwio r12, 0(r13) hope it can help Sylvain
