TCP Nichestack
Hi everyone,
I run the simple socket server example, and I got the error as below.
Full message error is :
dtrap - needs breakpoint
panic: pktdemux: got null pkt
ip_exit: calling func 0x400f814
netclose: closing iface Altera TSE MAC ethernet
ip_exit: calling func 0x401321c
Anyone could help? Thanks in advance.
Caridee
What version of the tools are you running? Are you just doing the regular Simple Socket Server example or have you modified it?
Jake
I am using version 8.0.
I think rcvd queue was corrupted.... what should I do?
Do you have access to a newer version of the tools? I think the TSE MAC driver and NicheStack were in a bit of a state of flux in 8.0. Specifically it seems that in 8.0 they still had hard-coded paths in the TSE MAC driver for the SGDMA controllers. As such, I think you can receive this error if you haven't named the components in your SoPC system exactly like they are named in the reference design.
Jake
What do u mean by hard-coded paths in the TSE MAC driver for the SGDMA controller?
I am using the design example inside the installation path. Could u pls specify which components i need to rename correctly?
Thanks a lot
If you are using the design example from the installation path, then the names should be correct. In which case your problem is different. Would you care to post your project here?
