hello everyone,
I'd like to make some bench of the Ethernet connextion with the two protocols : TCP and UDP (to compare). - Is someone has already progs that measure the througput ? (http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/rolleyes.gif I will not be pleased to do it by myself:rolleyes: ) - Is someone has tested a gigabit connection (with a daughter card) on altera dev Boards ? if yes what was your throughput ? thanks. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/rolleyes.gifLink Copied
