공지
12748 토론
The problem concerning uClinux uploading to UP3
명예로운 기여자 II
2,019 조회수
Hello everyone!I need your help now...
The problem is concerning uClinux uploading to UP3 board.
Here is my developing enviornment:
target board: UP3 Education Kit
Cyclone EP1C6Q240
TC58FVT160 Flash Memory 2MB(1M*16b)
1S42S16400B SDRAM 8MB
128KB(64K*16b) SRAM
Software: Quartus 4.2 + NIOS IDE1.0
Nios2linux1_3
Since there is no ptf file from linux_example support for UP3,i have no idea.
I try to use NiosII_lab_up3 ptf.
According to the Linux Quick Start Guide,creat Linux Kernel Project,Configure Kernel,then Build Project,waiting...
the final error are as follows:
2.6.x/drivers/char/altera_pio_button.c:112: error: `na_button_pio_irq' undeclared (first use in this function)
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/altera_pio_button.c:112: error: (Each undeclared identifier is reported only once
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/altera_pio_button.c:112: error: for each function it appears in.)
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/altera_pio_button.c: In function `button_release':
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drmake: Leaving directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x'
ivers/char/altera_pio_button.c:156: error: `na_button_pio_irq' undeclared (first use in this function)
make[3]: *** [drivers/char/altera_pio_button.o] Error 1
make[2]: *** [drivers/char] Error 2
make[1]: *** [drivers] Error 2
make: *** [_all] Error 2
And what's the matter,need to modify the UP3 ptf file? and how to?I'm a newer in this developing
what i should complete,is Web Server using in Industry data gathering,based on Nios-uClinux board system.(UP3)
Thank you for everyone here, it&#39;s my first title here,and english is not good. Maybe should description more details.http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
0 포인트
11 응답
명예로운 기여자 II
1,042 조회수
Hi, sounds like a cool little project. Though I have to warn you that the board may not have enough flash or sdram to comfortably run Linux.
The current distribution uses the first 2 MB of flash to hold the kernel and any remaining flash to hold a read-only filesystem. With only 2 MB of space, I&#39;d recommend browsing around the forum to learn how to use u-boot and a compressed kernel. You should be able to fit u-boot and the kernel into the first meg of flash.
The next step would be to ensure that you&#39;re flash is supported in the kernel and to set up a flash partition map so that you can mount the last MB of flash as a filesystem. With only 1 MB to work with, it would be best to use cramfs I think... again, people on this forum have successfully used cramfs in the past, so searching around should give you some answers.
As for the error that you&#39;re getting during the build process, configure your kernel to turn off Altera PIO Button support... you can find it at:
Device Drivers
--> Character Devices
----> Nios PIO buttons support
Once you turn it off, try re-building again, it should help.
0 포인트
명예로운 기여자 II
1,042 조회수
Hi:
Thank you very much!
This UP3 board is supply by Altera,using for the university NIOS
competition.So we have no chose,also should build a web server on this
board,based on uClinux operating system.
According your suggestion,turn &#39;Nios PIO buttons support&#39; off,build
again,the former error disppear,but another error appears:
nux.kernel_0.1.5/linux-2.6.x&#39;
nel_0.1.5/linux-2.6.x/drivers/net/smc91111.c:2062: warning:
`MOD_DEC_USE_COUNT&#39; is deprecated (declared at
ux.kernel_0.1.5/linux-2.6.x/include/linux/module.h:567)
ux.kernel_0.1.5/linux-2.6.x/drivers/net/smc91111.c: In function
`init_module&#39;:
ux.kernel_0.1.5/linux-2.6.x/drivers/net/smc91111.c:2173: warning:
assignment from incompatible pointer type
make[3]: *** [drivers/net/smc91111.o] Error 1
make[2]: *** [drivers/net] Error 2
Then i think it&#39;s the smc9111&#39;s problem, so i turn it off
other errors appear:
arch/nios2nommu/lib/.checksum.o.d: done.
CC arch/nios2nommu/lib/string.o
arch/nios2nommu/lib/.string.o.d: done.
AR arch/nios2nommu/lib/lib.a
GEN .version
CHK include/linux/compile.h
UPD include/linux/compile.h
CC init/version.o
init/.version.o.d: done.
LD init/built-in.o
LD .tmp_vmlinux1
nios2-elf-ld: region ram is full (.tmp_vmlinux1 section .text)
nios2-elf-ld: region ram is full (.tmp_vmlinux1 section .bss)
nios2-elf-ld: section .data [00020000 -> 0002dfff] overlaps section .text
[00020000 -> 0017b43b]
nios2-elf-ld: section .init [0002e000 -> 0003a51f] overlaps section .text
nios2-elf-ld: section .bss [0003a520 -> 0004afc7] overlaps section .text
nios2-elf-ld: section .sbss [00020000 -> 0002003c] overlaps section .text
make[1]: *** [.tmp_vmlinux1] Error 1
I don&#39;t know how to deal with this problem.
Another questions:
As some other embedded developing board as ARM-9,it has some crossing complie tools(arm-gcc), using in developing application through linux.
So what about NIOS-board, does NIOS has the likely gcc developing eviornment(NIOS-gcc)
When i develop the U-boot, do i need to using the nios-gcc, and how,using in linux system....?
Thank you again!:)
Best Regards!
0 포인트
명예로운 기여자 II
1,042 조회수
Hi Justin,
Yes, you should use nios2-elf-xxx. When building u-boot for Nios-II, nios2-elf is the default
cross compile prefix.
--Scott
0 포인트
명예로운 기여자 II
1,042 조회수
Hi:
This days I browse around the forum,and try to find how to use u-boot.
But where can I download the u-boot and the nios2-elf-gcc tool.
Thank you!
-Justin
0 포인트
명예로운 기여자 II
1,042 조회수
Hi Justin,
You can get u-boot from two places. The official sources can be found at:
http://www.sourceforge.net/projects/u-boot (http://www.sourceforge.net/projects/u-boot
The source tree at sourceforge contains the sources for all supported
architectures and boards. You can also get the u-boot sources from:
http://www.psyent.com/download (http://www.psyent.com/download
The sources at psyent contain only the files necessary to support Nios-II, and
a few of the files have minor changes to support an error/warning free build
using the standard Nios-II tools under cygwin. The psyent site from time-to-time
also has certain updates applied before they are incorporated into the
source tree a sourceforge (u-boot patches can take as long as 3 months
to be added to the sourceforge tree).
As for the nios2-elf-xxx tools ... they&#39;re part of the Nios-II development kit.
I believe you can download the tools from the Altera website ... but I&#39;m not
sure ... never needed to do this.
--Scott
0 포인트
명예로운 기여자 II
1,042 조회수
Hi again:)
Thank you for your given links, i have down the software as follows:
1:uClinux-dist-20041215.tar
2:nios-gcc.tar
3:u-boot-1.1.2.tar
And today i try to compile the uClinux kernel for NIOS,follow the point steps:
$ make xconfig
$ make dep
$ make
but when the final step &#39;make&#39;,following info appears:
/home/JustinYan/uClinux-dist/linux-2.4.x/include/linux/coda.h:116:
redefinition
of `struct timespec&#39;
{standard input}: Assembler messages:
{standard input}:824: Error: Unknown pseudo-op: `.subsection&#39;
{standard input}:832: Error: Unknown pseudo-op: `.previous&#39;
{standard input}:1000: Error: Unknown pseudo-op: `.subsection&#39;
{standard input}:1008: Error: Unknown pseudo-op: `.previous&#39;
make: *** [init/main.o] Error 1
I have no idea about it.why?
The another problem i meet,is about the rpm command.
I have download &#39;cdk-nios-example-u-boot-20040316cvs-20040317.src.rpm&#39; for the U-boot.
when:
JustinYan@JUSTINYAN ~/setup/cdk-nios-example-u-boot
$ rpm -ivh cdk-nios-example-u-boot-20040316cvs-20040317.src.rpm
$ rpm -qi cdk-nios-example-u-boot-20040316cvs-20040317.src.rpm
package cdk-nios-example-u-boot-20040316cvs-20040317.src.rpm is not installed
why this package is not installed, the rpm command using is correct,i think.
I&#39;m a beginner , so forgive me for asking this simple questions.
Thank you again!:)
Best Regards!
Justin
0 포인트
명예로운 기여자 II
1,042 조회수
Hi~Anybody here?
The first problem above has been solved today.
I have convert the kernel into a raw binary image--linux.bin(2.4MB),
and compress the binary image to linux.bin.gz(1.1MB)
Then package linux.bin.gz for U-Boot,
but when i build the U-Boot in this final step:
# make make: Entering directory `/usr/Setup_Nios/u-boot-1.1.2/tools&#39; make: `.depend&#39; is up to date. make: Leaving directory `/usr/Setup_Nios/u-boot-1.1.2/tools&#39; make: Entering directory `/usr/Setup_Nios/u-boot-1.1.2/examples&#39; make: `.depend&#39; is up to date. make: Leaving directory `/usr/Setup_Nios/u-boot-1.1.2/examples&#39; make: Entering directory `/usr/Setup_Nios/u-boot-1.1.2/post&#39; make: `.depend&#39; is up to date. make: Leaving directory `/usr/Setup_Nios/u-boot-1.1.2/post&#39; make: Entering directory `/usr/Setup_Nios/u-boot-1.1.2/post/cpu&#39; make: `.depend&#39; is up to date. make: Leaving directory `/usr/Setup_Nios/u-boot-1.1.2/post/cpu&#39; make -C tools all make: Entering directory `/usr/Setup_Nios/u-boot-1.1.2/tools&#39; make: Leaving directory `/usr/Setup_Nios/u-boot-1.1.2/tools&#39; make -C examples all make: Entering directory `/usr/Setup_Nios/u-boot-1.1.2/examples&#39; nios-elf-gcc -g  -Os    -D__KERNEL__ -DTEXT_BASE=0x018c0000 -I/usr/Setup_Nios/u-boot-1.1.2/include -fno-builtin -ffreestanding -nostdinc -isystem /usr/local/nios-elf/lib/gcc-lib/nios-elf/2.9-nios-010801-20030923/include -pipe  -m32 -DCONFIG_NIOS -D__NIOS__ -ffixed-g7 -gstabs -Wall -Wno-trigraphs -g  -Os    -D__KERNEL__ -DTEXT_BASE=0x018c0000 -I/usr/Setup_Nios/u-boot-1.1.2/include -fno-builtin -ffreestanding -nostdinc -isystem /usr/local/nios-elf/lib/gcc-lib/nios-elf/2.9-nios-010801-20030923/include -pipe  -m32 -DCONFIG_NIOS -D__NIOS__ -ffixed-g7 -gstabs -I.. -Bstatic -T /usr/Setup_Nios/u-boot-1.1.2/board/altera/dk1c20/u-boot.lds -Ttext 0x018c0000   hello_world.c   -o hello_world /usr/local/nios-elf/lib/gcc-lib/nios-elf/2.9-nios-010801-20030923/../../../../nios-elf/bin/ld: cannot open crt0.o: No such file or directory collect2: ld returned 1 exit status nios-elf-gcc: file path prefix `static&#39; never used make: *** Error 1 make: Leaving directory `/usr/Setup_Nios/u-boot-1.1.2/examples&#39; make: *** Error 2
This time, I really don&#39;t know how to fix this error.
Can anyone tell me how to solve this problem?
Thank you very much!!!
Best regards!
Justin
0 포인트
명예로운 기여자 II
1,042 조회수
Hi Scott:
I can&#39; open this link: http://www.psyent.com/download (http://www.psyent.com/download
Can you sent me the U-boot sources, containing only the files necessary to support Nios-II, using in email.
My email address is BTEL221@163.com
Regards!
Justin
0 포인트
명예로운 기여자 II
1,042 조회수
Hi Justin,
My first recommendation is: delete anything and everything you downloaded from
the cdk4nios project -- It&#39;s dead ... it&#39;s junk ... it never amounted to much more than
a semester project ... and it does not support nios-ii
> using in email.
It will my pleasure ... but you must promise to get rid of the CDK4NIOS code ;-)
--Scott
0 포인트
명예로운 기여자 II
1,042 조회수
Hi:
Thank you very very much! Scott:)
My board is UP3,with Cyclone EP1C6Q240(with CPU 48MHz),TC58FVT160 Flash Memory 2MB(1M*16b),1S42S16400B SDRAM 8MB,128KB(64K*16b) SRAM.
So i should create a suitable u-boot for this board,because u-boot-nios2-src just has the pci5441 and pk1c20.
And i should modify the sample files, and fit it to UP3.
1:<target_board>.h include/configs/up3.h
2:<target_board>.c board/up3/up3.c
3:flash driver board/up3/flash.c
The first problem is that i can&#39;t find the up3-flash datasheet(TC58FVT160),
to use in the flash.c. No help in the UP3 munual reference.
And in the work of creating up3.h,just getting little info from the SOPC Builder,a exiting up3_board example.Just like the below info:
CPU: Clock 48.0MHz Base 0x00000000 End 0x000007FF
jtag_uart: JTAG UART Base 0x00000800 End 0x00000807
ext_ram:Sram_UP3 Base 0x00020000 End 0x0003FFFF
So the second problem is where can I find some details using for this u-boot work,such as,
CFG_Nios_CONSOLE,CF G_GBL_DATA_OFFSET,CFG_Nios_TMRBASE,CFG_Nios_TMRIRQ and so on,
because the UP3 munual reference doesn&#39;t have this data.
Thank you again~!
Regards!
Justin
0 포인트
명예로운 기여자 II
1,042 조회수
Hi Justin,
http://www.toshiba.com/taec/components/dat...60aft_axb_e.pdf (http://www.toshiba.com/taec/components/datasheet/tc58fvtb160aft_axb_e.pdf
You might want to search the u-boot sources at sourceforge to find a board that supports
this flash device and just copy it into your board-specific tree.
Yes, u-boot configuration isn&#39;t the easiest task. A nice document for Nios-II would be great ... maybe
I&#39;ll take a stab at it once I have some spare time ;-) That being said, let me try to help with the
following minimum configuration:
1. top-level configuration
All of the following are configured via SOPC builder and are in your ptf file with the tag shown
in (braces):
CONFIG_SYS_CLK_FREQ -the Nios-II clock frequency in hertz (clock_freq)
CFG_RESET_ADDR -the Nios-II reset address (reset_offset + the device base)
CFG_EXCEPTION_ADDR - The Nios-II Exception address (exc_offset)
CFG_ICACHE_SIZE - Size of the icache in bytes or zero (nasys_icache_size)
CFG_ICACHELINE_SIZE - Size of icache line in bytes (nasys_icache_line_size)
CFG_DCACHE_SIZE - Size of the dcache in bytes or zero (nasys_dcache_size)
CFG_DCACHELINE_SIZE - Size of the dcache line in bytes (nasys_dcache_line_size)
2. memory base addresses
Define all of these ... set size to zero if not applicable. These should be available in
your SOPC builder memory map.
CFG_FLASH_BASE - base address of flash
CFG_FLASH_SIZE - size in bytes of flash
CFG_SDRAM_BASE - base address of SDRAM
CFG_SDRAM_SIZE - size in bytes of SDRAM
CFG_SRAM_BASE - base address of SRAM
CFG_SRAM_SIZE - size in bytes of SRAM
3. memory organization
CFG_MONITOR_LEN - the size in bytes reserved for u-boot
CFG_GBL_DATA_SIZE - the size in bytes reserved for u-boot&#39;s global data (128 will do)
CFG_MALLOC_LEN - the size in bytes of the u-boot heap
These can be quite confusing, but they let you fine-tune your configuration. Normally, they&#39;re
all defined relative to the u-boot text base. See the PK1C20.h file for example.
CFG_MONITOR_BASE - u-boot text base address (same as the .cfg file)
CFG_MALLOC_BASE - base address of heap
CFG_GBL_DATA_OFFSET - base address of u-boot&#39;s global data
CFG_INIT_SP - initial stack pointer
4. required component configuration
u-boot needs a uart and a timer. Here&#39;s the configuration macros you should use:
CFG_NIOS_TMRBASE - base address of the timer used by u-boot
CFG_NIOS_TMRIRQ - the interrupt request number used by the timer
CFG_NIOS_TMRMS - the timer interval in milliseconds
If the timer provides period registers AND the default count is not acceptable
to you, you can configure CFG_NIOS_TMRCNT.
CFG_NIOS_TMRCNT - value used to load the period registers of the u-boot timer.
CFG_HZ - number of hertz per timer tick. This is used by networking code and is dependent
on the timer macros above.
CFG_NIOS_CONSOLE - Base address of the uart or jtag uart component.
CONFIG_CONSOLE_JTAG - Define this when using the jtag uart
CFG_NIOS_FIXEDBAUD - Define this when uart is fixed baudrate or with jtag uart
CONFIG_BAUDRATE - the initial baudrate (or the fixed baudrate) in bps
CFG_BAUDRATE_TABLE - a table of allowed baudrates. This has one entry for fixed rate uart/jtag
E.g.:
# define CFG_BAUDRATE_TABLE {115200} /* It&#39;s fixed */
or# define CFG_BAUDRATE_TABLE {9600, 19200, 115200} /* Allows selection of rate via cli */
I hope this is useful ... configuring u-boot via a gui would be great ... but, good or bad,
if you want a very high level of control, editing a configuration file will force you to really
know your code.
If you have any questions or need additional information, just post or shoot me some email.
--Scott
0 포인트
응답
