12748 Discussions
The problem concerning uClinux uploading to UP3
Hello everyone!I need your help now...
The problem is concerning uClinux uploading to UP3 board.
Here is my developing enviornment:
target board: UP3 Education Kit
Cyclone EP1C6Q240
TC58FVT160 Flash Memory 2MB(1M*16b)
1S42S16400B SDRAM 8MB
128KB(64K*16b) SRAM
Software: Quartus 4.2 + NIOS IDE1.0
Nios2linux1_3
Since there is no ptf file from linux_example support for UP3,i have no idea.
I try to use NiosII_lab_up3 ptf.
According to the Linux Quick Start Guide,creat Linux Kernel Project,Configure Kernel,then Build Project,waiting...
the final error are as follows:
2.6.x/drivers/char/altera_pio_button.c:112: error: `na_button_pio_irq' undeclared (first use in this function)
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/altera_pio_button.c:112: error: (Each undeclared identifier is reported only once
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/altera_pio_button.c:112: error: for each function it appears in.)
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/altera_pio_button.c: In function `button_release':
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drmake: Leaving directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x'
ivers/char/altera_pio_button.c:156: error: `na_button_pio_irq' undeclared (first use in this function)
make[3]: *** [drivers/char/altera_pio_button.o] Error 1
make[2]: *** [drivers/char] Error 2
make[1]: *** [drivers] Error 2
make: *** [_all] Error 2
And what's the matter,need to modify the UP3 ptf file? and how to?I'm a newer in this developing
what i should complete,is Web Server using in Industry data gathering,based on Nios-uClinux board system.(UP3)
Thank you for everyone here, it&#39;s my first title here,and english is not good. Maybe should description more details.http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
Hi, sounds like a cool little project. Though I have to warn you that the board may not have enough flash or sdram to comfortably run Linux.
The current distribution uses the first 2 MB of flash to hold the kernel and any remaining flash to hold a read-only filesystem. With only 2 MB of space, I&#39;d recommend browsing around the forum to learn how to use u-boot and a compressed kernel. You should be able to fit u-boot and the kernel into the first meg of flash.
The next step would be to ensure that you&#39;re flash is supported in the kernel and to set up a flash partition map so that you can mount the last MB of flash as a filesystem. With only 1 MB to work with, it would be best to use cramfs I think... again, people on this forum have successfully used cramfs in the past, so searching around should give you some answers.
As for the error that you&#39;re getting during the build process, configure your kernel to turn off Altera PIO Button support... you can find it at:
Device Drivers
--> Character Devices
----> Nios PIO buttons support
Once you turn it off, try re-building again, it should help.
Hi:
Thank you very much!
This UP3 board is supply by Altera,using for the university NIOS
competition.So we have no chose,also should build a web server on this
board,based on uClinux operating system.
According your suggestion,turn &#39;Nios PIO buttons support&#39; off,build
again,the former error disppear,but another error appears:
nux.kernel_0.1.5/linux-2.6.x&#39;
nel_0.1.5/linux-2.6.x/drivers/net/smc91111.c:2062: warning:
`MOD_DEC_USE_COUNT&#39; is deprecated (declared at
ux.kernel_0.1.5/linux-2.6.x/include/linux/module.h:567)
ux.kernel_0.1.5/linux-2.6.x/drivers/net/smc91111.c: In function
`init_module&#39;:
ux.kernel_0.1.5/linux-2.6.x/drivers/net/smc91111.c:2173: warning:
assignment from incompatible pointer type
make[3]: *** [drivers/net/smc91111.o] Error 1
make[2]: *** [drivers/net] Error 2
Then i think it&#39;s the smc9111&#39;s problem, so i turn it off
other errors appear:
arch/nios2nommu/lib/.checksum.o.d: done.
CC arch/nios2nommu/lib/string.o
arch/nios2nommu/lib/.string.o.d: done.
AR arch/nios2nommu/lib/lib.a
GEN .version
CHK include/linux/compile.h
UPD include/linux/compile.h
CC init/version.o
init/.version.o.d: done.
LD init/built-in.o
LD .tmp_vmlinux1
nios2-elf-ld: region ram is full (.tmp_vmlinux1 section .text)
nios2-elf-ld: region ram is full (.tmp_vmlinux1 section .bss)
nios2-elf-ld: section .data [00020000 -> 0002dfff] overlaps section .text
[00020000 -> 0017b43b]
nios2-elf-ld: section .init [0002e000 -> 0003a51f] overlaps section .text
nios2-elf-ld: section .bss [0003a520 -> 0004afc7] overlaps section .text
nios2-elf-ld: section .sbss [00020000 -> 0002003c] overlaps section .text
make[1]: *** [.tmp_vmlinux1] Error 1
I don&#39;t know how to deal with this problem.
Another questions:
As some other embedded developing board as ARM-9,it has some crossing complie tools(arm-gcc), using in developing application through linux.
So what about NIOS-board, does NIOS has the likely gcc developing eviornment(NIOS-gcc)
When i develop the U-boot, do i need to using the nios-gcc, and how,using in linux system....?
Thank you again!:)
Best Regards!
Hi Justin,
Yes, you should use nios2-elf-xxx. When building u-boot for Nios-II, nios2-elf is the default
cross compile prefix.
--Scott
Hi:
This days I browse around the forum,and try to find how to use u-boot.
But where can I download the u-boot and the nios2-elf-gcc tool.
Thank you!
-Justin
Hi Justin,
You can get u-boot from two places. The official sources can be found at:
http://www.sourceforge.net/projects/u-boot (http://www.sourceforge.net/projects/u-boot
The source tree at sourceforge contains the sources for all supported
architectures and boards. You can also get the u-boot sources from:
http://www.psyent.com/download (http://www.psyent.com/download
The sources at psyent contain only the files necessary to support Nios-II, and
a few of the files have minor changes to support an error/warning free build
using the standard Nios-II tools under cygwin. The psyent site from time-to-time
also has certain updates applied before they are incorporated into the
source tree a sourceforge (u-boot patches can take as long as 3 months
to be added to the sourceforge tree).
As for the nios2-elf-xxx tools ... they&#39;re part of the Nios-II development kit.
I believe you can download the tools from the Altera website ... but I&#39;m not
sure ... never needed to do this.
--Scott
Hi again:)
Thank you for your given links, i have down the software as follows:
1:uClinux-dist-20041215.tar
2:nios-gcc.tar
3:u-boot-1.1.2.tar
And today i try to compile the uClinux kernel for NIOS,follow the point steps:
$ make xconfig
$ make dep
$ make
but when the final step &#39;make&#39;,following info appears:
/home/JustinYan/uClinux-dist/linux-2.4.x/include/linux/coda.h:116:
redefinition
of `struct timespec&#39;
{standard input}: Assembler messages:
{standard input}:824: Error: Unknown pseudo-op: `.subsection&#39;
{standard input}:832: Error: Unknown pseudo-op: `.previous&#39;
{standard input}:1000: Error: Unknown pseudo-op: `.subsection&#39;
{standard input}:1008: Error: Unknown pseudo-op: `.previous&#39;
make: *** [init/main.o] Error 1
I have no idea about it.why?
The another problem i meet,is about the rpm command.
I have download &#39;cdk-nios-example-u-boot-20040316cvs-20040317.src.rpm&#39; for the U-boot.
when:
JustinYan@JUSTINYAN ~/setup/cdk-nios-example-u-boot
$ rpm -ivh cdk-nios-example-u-boot-20040316cvs-20040317.src.rpm
$ rpm -qi cdk-nios-example-u-boot-20040316cvs-20040317.src.rpm
package cdk-nios-example-u-boot-20040316cvs-20040317.src.rpm is not installed
why this package is not installed, the rpm command using is correct,i think.
I&#39;m a beginner , so forgive me for asking this simple questions.
Thank you again!:)
Best Regards!
Justin
Hi~Anybody here?
The first problem above has been solved today.
I have convert the kernel into a raw binary image--linux.bin(2.4MB),
and compress the binary image to linux.bin.gz(1.1MB)
Then package linux.bin.gz for U-Boot,
but when i build the U-Boot in this final step:
# make make: Entering directory `/usr/Setup_Nios/u-boot-1.1.2/tools&#39; make: `.depend&#39; is up to date. make: Leaving directory `/usr/Setup_Nios/u-boot-1.1.2/tools&#39; make: Entering directory `/usr/Setup_Nios/u-boot-1.1.2/examples&#39; make: `.depend&#39; is up to date. make: Leaving directory `/usr/Setup_Nios/u-boot-1.1.2/examples&#39; make: Entering directory `/usr/Setup_Nios/u-boot-1.1.2/post&#39; make: `.depend&#39; is up to date. make: Leaving directory `/usr/Setup_Nios/u-boot-1.1.2/post&#39; make: Entering directory `/usr/Setup_Nios/u-boot-1.1.2/post/cpu&#39; make: `.depend&#39; is up to date. make: Leaving directory `/usr/Setup_Nios/u-boot-1.1.2/post/cpu&#39; make -C tools all make: Entering directory `/usr/Setup_Nios/u-boot-1.1.2/tools&#39; make: Leaving directory `/usr/Setup_Nios/u-boot-1.1.2/tools&#39; make -C examples all make: Entering directory `/usr/Setup_Nios/u-boot-1.1.2/examples&#39; nios-elf-gcc -g  -Os    -D__KERNEL__ -DTEXT_BASE=0x018c0000 -I/usr/Setup_Nios/u-boot-1.1.2/include -fno-builtin -ffreestanding -nostdinc -isystem /usr/local/nios-elf/lib/gcc-lib/nios-elf/2.9-nios-010801-20030923/include -pipe  -m32 -DCONFIG_NIOS -D__NIOS__ -ffixed-g7 -gstabs -Wall -Wno-trigraphs -g  -Os    -D__KERNEL__ -DTEXT_BASE=0x018c0000 -I/usr/Setup_Nios/u-boot-1.1.2/include -fno-builtin -ffreestanding -nostdinc -isystem /usr/local/nios-elf/lib/gcc-lib/nios-elf/2.9-nios-010801-20030923/include -pipe  -m32 -DCONFIG_NIOS -D__NIOS__ -ffixed-g7 -gstabs -I.. -Bstatic -T /usr/Setup_Nios/u-boot-1.1.2/board/altera/dk1c20/u-boot.lds -Ttext 0x018c0000   hello_world.c   -o hello_world /usr/local/nios-elf/lib/gcc-lib/nios-elf/2.9-nios-010801-20030923/../../../../nios-elf/bin/ld: cannot open crt0.o: No such file or directory collect2: ld returned 1 exit status nios-elf-gcc: file path prefix `static&#39; never used make: *** Error 1 make: Leaving directory `/usr/Setup_Nios/u-boot-1.1.2/examples&#39; make: *** Error 2
This time, I really don&#39;t know how to fix this error.
Can anyone tell me how to solve this problem?
Thank you very much!!!
Best regards!
Justin
Hi Scott:
I can&#39; open this link: http://www.psyent.com/download (http://www.psyent.com/download
Can you sent me the U-boot sources, containing only the files necessary to support Nios-II, using in email.
My email address is BTEL221@163.com
Regards!
Justin
Hi Justin,
My first recommendation is: delete anything and everything you downloaded from
the cdk4nios project -- It&#39;s dead ... it&#39;s junk ... it never amounted to much more than
a semester project ... and it does not support nios-ii
> using in email.
It will my pleasure ... but you must promise to get rid of the CDK4NIOS code ;-)
--Scott
Hi:
Thank you very very much! Scott:)
My board is UP3,with Cyclone EP1C6Q240(with CPU 48MHz),TC58FVT160 Flash Memory 2MB(1M*16b),1S42S16400B SDRAM 8MB,128KB(64K*16b) SRAM.
So i should create a suitable u-boot for this board,because u-boot-nios2-src just has the pci5441 and pk1c20.
And i should modify the sample files, and fit it to UP3.
1:<target_board>.h include/configs/up3.h
2:<target_board>.c board/up3/up3.c
3:flash driver board/up3/flash.c
The first problem is that i can&#39;t find the up3-flash datasheet(TC58FVT160),
to use in the flash.c. No help in the UP3 munual reference.
And in the work of creating up3.h,just getting little info from the SOPC Builder,a exiting up3_board example.Just like the below info:
CPU: Clock 48.0MHz Base 0x00000000 End 0x000007FF
jtag_uart: JTAG UART Base 0x00000800 End 0x00000807
ext_ram:Sram_UP3 Base 0x00020000 End 0x0003FFFF
So the second problem is where can I find some details using for this u-boot work,such as,
CFG_Nios_CONSOLE,CF G_GBL_DATA_OFFSET,CFG_Nios_TMRBASE,CFG_Nios_TMRIRQ and so on,
because the UP3 munual reference doesn&#39;t have this data.
Thank you again~!
Regards!
Justin
Hi Justin,
http://www.toshiba.com/taec/components/dat...60aft_axb_e.pdf (http://www.toshiba.com/taec/components/datasheet/tc58fvtb160aft_axb_e.pdf
You might want to search the u-boot sources at sourceforge to find a board that supports
this flash device and just copy it into your board-specific tree.
Yes, u-boot configuration isn&#39;t the easiest task. A nice document for Nios-II would be great ... maybe
I&#39;ll take a stab at it once I have some spare time ;-) That being said, let me try to help with the
following minimum configuration:
1. top-level configuration
All of the following are configured via SOPC builder and are in your ptf file with the tag shown
in (braces):
CONFIG_SYS_CLK_FREQ -the Nios-II clock frequency in hertz (clock_freq)
CFG_RESET_ADDR -the Nios-II reset address (reset_offset + the device base)
CFG_EXCEPTION_ADDR - The Nios-II Exception address (exc_offset)
CFG_ICACHE_SIZE - Size of the icache in bytes or zero (nasys_icache_size)
CFG_ICACHELINE_SIZE - Size of icache line in bytes (nasys_icache_line_size)
CFG_DCACHE_SIZE - Size of the dcache in bytes or zero (nasys_dcache_size)
CFG_DCACHELINE_SIZE - Size of the dcache line in bytes (nasys_dcache_line_size)
2. memory base addresses
Define all of these ... set size to zero if not applicable. These should be available in
your SOPC builder memory map.
CFG_FLASH_BASE - base address of flash
CFG_FLASH_SIZE - size in bytes of flash
CFG_SDRAM_BASE - base address of SDRAM
CFG_SDRAM_SIZE - size in bytes of SDRAM
CFG_SRAM_BASE - base address of SRAM
CFG_SRAM_SIZE - size in bytes of SRAM
3. memory organization
CFG_MONITOR_LEN - the size in bytes reserved for u-boot
CFG_GBL_DATA_SIZE - the size in bytes reserved for u-boot&#39;s global data (128 will do)
CFG_MALLOC_LEN - the size in bytes of the u-boot heap
These can be quite confusing, but they let you fine-tune your configuration. Normally, they&#39;re
all defined relative to the u-boot text base. See the PK1C20.h file for example.
CFG_MONITOR_BASE - u-boot text base address (same as the .cfg file)
CFG_MALLOC_BASE - base address of heap
CFG_GBL_DATA_OFFSET - base address of u-boot&#39;s global data
CFG_INIT_SP - initial stack pointer
4. required component configuration
u-boot needs a uart and a timer. Here&#39;s the configuration macros you should use:
CFG_NIOS_TMRBASE - base address of the timer used by u-boot
CFG_NIOS_TMRIRQ - the interrupt request number used by the timer
CFG_NIOS_TMRMS - the timer interval in milliseconds
If the timer provides period registers AND the default count is not acceptable
to you, you can configure CFG_NIOS_TMRCNT.
CFG_NIOS_TMRCNT - value used to load the period registers of the u-boot timer.
CFG_HZ - number of hertz per timer tick. This is used by networking code and is dependent
on the timer macros above.
CFG_NIOS_CONSOLE - Base address of the uart or jtag uart component.
CONFIG_CONSOLE_JTAG - Define this when using the jtag uart
CFG_NIOS_FIXEDBAUD - Define this when uart is fixed baudrate or with jtag uart
CONFIG_BAUDRATE - the initial baudrate (or the fixed baudrate) in bps
CFG_BAUDRATE_TABLE - a table of allowed baudrates. This has one entry for fixed rate uart/jtag
E.g.:
# define CFG_BAUDRATE_TABLE {115200} /* It&#39;s fixed */
or# define CFG_BAUDRATE_TABLE {9600, 19200, 115200} /* Allows selection of rate via cli */
I hope this is useful ... configuring u-boot via a gui would be great ... but, good or bad,
if you want a very high level of control, editing a configuration file will force you to really
know your code.
If you have any questions or need additional information, just post or shoot me some email.
--Scott
