The problem of interrupt
hello!
I am learning how to edit a component,but there are two errors that I cann't solve,can anyone suggest me?
http://b32.photo.store.qq.com/http_imgload.cgi?/rurl4_b=b579f8b54f494fc69149a5de70a1aee97ae940bc75e456f68f02470592f5952d5058f6e366fb6918e7ccbf21ef48868f0212d77e18b3522b325715a7e1b185c098ba27d40c5804c65905e1cda0092f7025180e37&a=28&b=32
the code is:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity inter is
port(clk: in std_logic;
reset_n: in std_logic;
chipselect: in std_logic;
address: in std_logic;
write_n: in std_logic;
writedata: in std_logic_vector(31 downto 0);
read_n: in std_logic;
readdata: out std_logic_vector(31 downto 0);
irq: out std_logic);
end inter;
architecture behave of inter is
signal status:std_logic_vector(31 downto 0);
signal control:std_logic_vector(31 downto 0);
signal counter:std_logic_vector(23 downto 0);
signal sign:std_logic;
begin
process(reset_n,chipselect,write_n,read_n,writedata)
begin
if(reset_n='0')then
status<=(others=>'0');
control<=(others=>'0');
sign<='0';
elsif(chipselect='0')then
if(write_n='0')then
case address is
when '0'=>status<=writedata;
when '1'=>control<=writedata;
end case;
end if;
if(read_n='0')then
case address is
when '0'=>readdata<=status;
when '1'=>readdata<=control;
end case;
end if;
end if;
end process;
process(clk,chipselect,write_n)
begin
if(clk'event and clk='1')then
if(chipselect='0' and write_n='1' and control(0)='1' and status(0)='0')then
counter<=counter+1;
if(counter>"111111111111111111110000")then
sign<='1';
status<="000000000000000000000001";
else
sign<='0';
end if;
end if;
end if;
end process;
irq<=sign;
end behave;
thank you very much!
What problem do you have?
All the images that you send on this forum are unreadable. You should find another provider for them, or attach them to your message.
I have resolve the question,thank you all the same!
