12748 Discussions
Trying to get u-boot to boot my image
Hi hopefully someone can help and may I say thanks in advance!!!
my configuration
Cyclone III EP3C25
EPCS16 0x08001000 0x080017ff
SDRAM 0x00000000 0x01ffffff
TEXT_BASE 0x01FB0000
# define CFG_RESET_ADDR 0x08001000 /* Hard-reset address */
# define CFG_EXCEPTION_ADDR 0x0C000020 /* Exception entry point*/
# define CFG_NIOS_SYSID_BASE 0x08002800 /* System id address */
# define CFG_NIOS_EPCSBASE (0x08001000 + 0x400) /* EPCS register base */
So I build u-boot to produce the elf file and then :-
//# Creating .flash file for the FPGA configuration
sof2flash --epcs --input=mainboard.sof --output=mainboard.flash
//# Converting UBoot elf to FLASH file
elf2flash --epcs --after=mainboard.flash --input=u-boot.elf --output=u-boot.flash
//# Programming flash with u-boot
nios2-flash-programmer --epcs --base=0x08001400 u-boot.flash --debug
//# Programming flash with the FPGA configuration
nios2-flash-programmer --epcs --base=0x08001400 mainboard.flash --debug --go
U-boot starts and looks like this:-
U-Boot 1.3.2 (Nov 5 2009 – 11:45:20)
CPU : Nios-II
SYSID : 0ca68f29, Fri Oct 23 11:59:28 2009-11-05
BOARD : EP-3C25
*** Warning – bad CRC, using default environment
now a create my image file
nios2-elf-objcopy --remove-section .entry -O binary ScrougeMain.elf Scrouge.bin
gzip -9 -c Scrouge.bin > Scrouge.gz
u-boot/tools/mkimage.exe -d Scrouge.gz -A nios2 -O linux -T kernel -n "EP-3C25" -a 00000000 -e 00000000 -C gzip Scrouge.img
Now I transfer my image by Kermit (I haven’t tried to get the network stuff working yet) over the serial port
loadb 0x01000000 then do the Kermit stuff and the output is
# # Total Size = 0x0004e808 = 321544 Bytes
# # Start Addr = 0x01000000
So if I now issue an image info command I get the following
## Checking Image at 01000000 ...
Image Name: EP-3C25
Image Type: Nios-II Linux Kernel Image (gzip compressed)
Data Size: 321480 Bytes = 313.9 kB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
So now I want to test my image before I try and store it in the EPCS so I issue the bootm command and the following is displayed
## Booting image at 01000000 ...
Image Name: EP-3C25
Uncompressing Kernel Image ... OK
And then nothing happens
