12748 Discussions
panic: tcp_out - packet ptr underflow
I'm using Nios II 8.1 IDE
I've got a Custom CPU board with a Cyclone III and the National Semiconductor triple speed ethernet chip. I have the Niche Stack license.
I've successfully run code with the simple socket server as the basis.
For my final delivery I needed to add the Remote Config capability, so I "married" the two features (I tried this first on a NEEK development board and a subset of my code and was successful). The way I did this was make a project based on the "Remote Configuration" and added the Simple Socket Server Code I needed. I start the ssstask after the rctask - code snipet follows:
/* Create the main remote configuration task. */
TK_NEWTASK(&rctask);
printf("\nSimple Socket Server starting up\n");
/* Create NicheStack Tasks. */
TK_NEWTASK(&ssstask);
TK_NEWTASK(&EnetTask);
/* Application Specific Task Launching Code Block End */
/*This task is deleted because there is no need for it to run again */
error_code = OSTaskDel(OS_PRIO_SELF);
alt_uCOSIIErrorHandler(error_code, 0);
My new code runs just fine when I run from the IDE.
When I burn the program into flash and I try to connect to the server I get the following error:
dtrap - needs breakpoint
netclose: closing iface Altera TSE MAC ethernet
A bit more information. I do have other tasks and here are the priorities I've selected:
# define LOGIC1553_PRIORITY 10# define SENDENET_PRIORITY 12 //Send 1553 Data# define VFD_PRIORITY 14 # define SSS_PRIORITY 4# define TEN_FOUR_ENET_PIO 13# define DISCONN_CHECK 15
//// ADDED for remote configuration# define REMOTE_CONFIG_PRIORITY 5 // was 4 and hard coded
My simple socket server is Priority 4
Can anyone help me ?
