I tried adding a simple uart in nios 2, this is wat i did n wat i got..
I added uart to sopc system once with default options and once with variable baudrate. When generated and included in the bdf, in the default options case, i did not get any extra lines from nios system while in variable baudrate case i got four lines (txdata,rxdata,rts,cts). Somebody please explain why this happens.. And when i compile, it compiled successfully.. But when i tried running a simple hello world program from nios2 ide with system library's settings as stdin=uart and stdout=uart instead of jtag uart, after building and downloading, i get the error as Verify Failed! Why do i get this error?? Please help.. Also if somebody has example of uart in nios2 (both hardware and software) it would be of great help ..Link Copied
