UBIFS size issue
I am working with UBIFS,
When I am giving 55MiB of vol size, by following command
ubimkvol /dev/ubi0 -N vol -s 55MiB
I could able to see only, 49 MiB of space when Kernel boot-up.
Can any one please, give me some inputs regarding same.
Ashwin Rase
--- Quote Start ---
--- Quote End ---
Can't you get the answer from here ?
http://www.linux-mtd.infradead.org/faq/ubifs.html#l_df_report
Kazu
Thanks for reply,
I went through the links, it has mentioned about the free space i.e. "Use%" from below logs .
It also informs that how it varies. Following logs of mine is showing the same.
But I actually want to know that ,
when I create a volume by 55 MiB size and I get it as 49 MiB size after df -h, then
for what purpose 6 MiB (55MiB - 49MiB) is used ?
Why I could not able to see 55 MiB size, as allocated total space. ?
-- Following is the log -----
root@dhcppc7:~# df -h
Filesystem Size Used Available Use% Mounted on
ubi0:vol_1 49.2M 44.0M 5.2M 90% /
root@dhcppc7:~# sync
ubi0:vol_1 49.2M 43.0M 6.2M 87% /
Thank you,
Ashwin Rase.
--- Quote Start ---
--- Quote End ---
UBIFS always reports conservative amount of free space,
I think that the reason is written here.
http://www.linux-mtd.infradead.org/doc/ubifs.html#l_spaceacc
Kazu
Thanks Kazuyasu for your help
