12746 Discussions
UCLinux build errors with DE2 Board 2C35.
I installed the Nios II Linux v1.4 released.
System : XP, quartus v51, nios v51.
Board : DE2 with 2C35.
I do exactly what is say in the microtronix “Quick Start Quide.pdf” but I’ve got some errors when i build my linux kernel.
/cygdrive/c/altera/kits/nios2_51/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/ide/ide.c: In function `init_hwif_default': /cygdrive/c/altera/kits/nios2_51/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/ide/ide.c:262: error: `na_ide_ide' undeclared (first use in this function) /cygdrive/c/altera/kits/nios2_51/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/ide/ide.c:262: error: (Each undeclared identifier is reported only once /cygdrive/c/altera/kits/nios2_51/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/ide/ide.c:262: error: for each function it appears in.) /cygdrive/c/altera/kits/nios2_51/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/ide/ide.c: In function `init_ide_data': /cygdrive/c/altera/kits/nios2_51/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/ide/ide.c:313: error: `na_ide_ide_irq' undeclared (first use in this function) make: *** Error 1 make: *** Error 2 make: *** Error 2 make: *** Error 2 make: Leaving directory `/cygdrive/c/altera/kits/nios2_51/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x'
Does Nios II Linux v1.4 support DE2_Board ?
I think that my kernel configuration is good. Maybe one problem with the *.ptf but i don’t know exactly. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif
Could u help me,
Thanks!
hi,
whiche .ptf do u use ?
the hardware configuration of your kernel must match the content of the .ptf used, if not problem with drivers will occur.
see also :
http://forum.niosforum.com/forum/index.php...ic=3667&hl=2c35 (http://forum.niosforum.com/forum/index.php?showtopic=3667&hl=2c35
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif
I used diferent PTF, for exemple:
The Altera exemple "std_2C35.ptf" or the "nios_0.ptf" provide in the DE2 demonstration. Finally I tried with a personal ptf and each time it&#39;s the same error. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
For the other section of this forum, i &#39;ve already see it. But the iriver problem&#39;s come when he want run linux. Me, i&#39;ve a problem for build it.
hi,
back to kernel configuration :
did u "Turn off: Device Drivers -> ATA/ATAPI/MFM/RLL support" as indicated in the quick start guide when configuring kernel ? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/rolleyes.gif
Hi pairin20,
I think you need to remove IDE support from your kernel configuration. It can be found at:
Device Drivers --->
ATA/ATAPI/MFM/RLL support --->
< > ATA/ATAPI/MFM/RLL support
sdhnain and MFM, u are brilliant !!! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/tongue.gif
Thanks!
I &#39;d like build my system with a DE2 exemple ptf, i use the one named "nios_0.ptf" of DE2_NET application. And i&#39;ve again some driver error when i build my kernel.
What can i do ? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
--- Quote Start ---
originally posted by pairin20@May 14 2006, 10:20 PM
i &#39;d like build my system with a de2 exemple ptf, i use the one named "nios_0.ptf" of de2_net application. and i&#39;ve again some driver error when i build my kernel.
make: *** error 1 make: *** error 2 make: *** error 2 make: *** error 2 make: leaving directory
what can i do ?  http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/sad.gif
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15356)</div>
--- Quote End ---
DE2 has different hardware from the Altera&#39;s Nios II 2C35 dev board.
For Eithernet DE2 uses DM9000, while Altera&#39;s Nios II dev board use SMC91111.
You have to check only what is available to your board in kernel config.
Another advice, work on Linux and follow the buildroot guide,
http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174)
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/mad.gif http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
--- Quote Start ---
http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/unsure.gif   http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/blink.gif   http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/mad.gif   http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/sad.gif
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15359)</div>
--- Quote End ---
hi parinin20
Do you have to modify two places in dm9000x.c ?
if not , you should be modified its ,as such following:
include/nios2_system.h
define na_DM9000A
define na_DM9000A_irq
/drivers/net/dm9000x.c:305: error: `na_dm9000_irq&#39; undeclared here (not in a function) "na_dm9000_irq" update to "na_DM9000A_irq"
drivers/net/dm9000x.c:162 # define DM9000_MIN_IO (na_dm9000) "na_dm9000" update to "DM9000A"
Hope to help you ! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
jay
In fact, for the moment i don&#39;t need the network fonctions. So I&#39;ve disable all in my config. Then I&#39;ve build my kernel perfectly.
I&#39;ve download it in RAM and when i launch the terminal it says this log:
nios2-terminal: log (http://c.beyls.free.fr/log-error.jpg
http://c.beyls.free.fr/log-error.JPG
What do u think about it ?
For the moment, I&#39;haven&#39;t load my filesystem. Do u think that my kernel is ok ?
--- Quote Start ---
originally posted by pairin20@May 15 2006, 05:19 AM
in fact, for the moment i don&#39;t need the network fonctions. so i&#39;ve disable all in my config. then i&#39;ve build my kernel perfectly.
i&#39;ve download it in ram and when i launch the terminal it says this log:
what do u think about it ?
for the moment, i&#39;haven&#39;t load my filesystem. do u think that my kernel is ok ?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15362)
--- quote end ---
--- Quote End ---
You must have root file system to run Linux.
If you want to use romfs on CFI for rootfs , you must modify the altera.c map file for mtd.
Last advice, follow buildroot guide.
There is a kernel image which you can try without compiling anything.
