I'd like download a .sof in memory, so I used this code:$ sof2flash --input=de2_net.sof --output=de2_net.flash --offset=0x0
$ nios2-flash-programmer --base=0x0 DE2_net.flash
but I think that the --base adress is not good. <div class='quotetop'>QUOTE </div> --- Quote Start --- No CFI table found at adress 0x00000000 Leaving target processor paused[/b] --- Quote End --- Should I better create a "srec" file ? What is the --base adress for the SREC or the FLASH file (in DE2 board) ? Thanks!
--- Quote Start --- originally posted by pairin20@May 15 2006, 07:03 AM hi,
i'd like download a .sof in memory, so i used this code:
$ nios2-flash-programmer --base=0x0 de2_net.flash
but i think that the --base adress is not good.
<div class='quotetop'>quote </div>
--- quote start ---
no cfi table found at adress 0x00000000
leaving target processor paused --- Quote End --- Should I better create a "srec" file ? What is the --base adress for the SREC or the FLASH file (in DE2 board) ? Thanks! <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15363)</div> [/b] --- Quote End --- DE2 uses EPCS16 for configuration, not CFI. You have to program sof to EPCS.
