12748 Discussions
USB host problem on DE2 board
I am trying to access the usb host on my DE2 board using ucLinux. I have followed the steps in the wiki at:
http://nioswiki.jot.com/wikihome/operating...host?revision=4 (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/usbhost?revision=4
I can download the image file to the board, however, when I start the terminal to boot the kernel, it hangs while loading the usb driver. Here is the output I receive:
[sopc builder]$ nios2-terminal.exe
nios2-terminal: connected to hardware target using jtag uart on cable
nios2-terminal: "usb-blaster [usb-0]", device 1, instance 0
nios2-terminal: (use the ide stop button or ctrl-c to terminate)
uncompressing linux... ok, booting the kernel.
linux version 2.6.17-uc1 (brian@loafy ) (gcc version 3.4.6)# 16 preempt sun nov 2
6 19:04:45 cst 2006
uclinux/nios ii
altera nios ii support © 2004 microtronix datacom ltd.
built 1 zonelists
kernel command line:
pid hash table entries: 64 (order: 6, 256 bytes)
dentry cache hash table entries: 1024 (order: 0, 4096 bytes)
inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
memory available: 5564k/8192k ram, 0k/0k rom (1518k kernel code, 1020k data)
mount-cache hash table entries: 512
net: registered protocol family 16
scsi subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
net: registered protocol family 2
ip route cache hash table entries: 1024 (order: 0, 4096 bytes)
tcp established hash table entries: 1024 (order: 0, 4096 bytes)
tcp bind hash table entries: 1024 (order: 0, 4096 bytes)
tcp: hash tables configured (established 1024 bind 1024)
tcp reno registered
io scheduler noop registered
io scheduler deadline registered (default)
serial: jtag uart driver $revision: 1.1 $
ttyj0 at mmio 0x81004000 (irq = 1) is a jtag_uart
dm9000 ethernet driver
eth%d: invalid ethernet mac address. please set using ifconfig
eth0: dm9000 at 80900090,80900094 irq 8 mac: 00:00:00:00:00:00
usbmon: debugfs is not available
driver isp1362-hcd, 2005-04-04
isp1362-hcd isp1362-hcd: isp1362 host controller
isp1362-hcd isp1362-hcd: new usb bus registered, assigned bus number 1
isp1362_hc_reset:
clock not ready after 20ms
isp1362-hcd isp1362-hcd: irq 4, io mem 0x80900080
isp1362_hc_start:
isp1362-hcd isp1362-hcd: isp1362 memory usage:
isp1362-hcd isp1362-hcd: istl: 2 * 256: 512 @ $0000:$0100
isp1362-hcd isp1362-hcd: intl: 16 * ( 64+8): 1152 @ $0200
isp1362-hcd isp1362-hcd: atl : 32 * ( 64+8): 2304 @ $0680
isp1362-hcd isp1362-hcd: used/free: 3968 128
At this point it stops indefinitely.
When I compare this with the output from the wiki, I notice that the following lines appear in my output and not on the wiki:
isp1362_hc_reset:
I'm thinking that I am missing some extra configuration for the FPGA. Currently, I download DE2_NET.sof to my DE2 board as specified in:
http://nioswiki.jot.com/wikihome/operating...s/tryoutuclinux (http://nioswiki.jot.com/wikihome/operatingsystems/tryoutuclinux
Does anyone have any idea what could be causing this problem? Help is this matter would be greatly appreciated.
--- Quote Start ---
originally posted by kael@Nov 29 2006, 04:34 AM
hello,
i am trying to access the usb host on my de2 board using uclinux.  i have followed the steps in the wiki at:
i can download the image file to the board, however, when i start the terminal to boot the kernel, it hangs while loading the usb driver.  here is the output i receive:
[SOPC Builder]$ nios2-terminal.exe
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
Uncompressing Linux... Ok, booting the kernel.
Linux version 2.6.17-uc1 (brian@loafy ) (gcc version 3.4.6)# 16 PREEMPT Sun Nov 2
6 19:04:45 CST 2006
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
Built 1 zonelists
Kernel command line:
PID hash table entries: 64 (order: 6, 256 bytes)
Dentry cache hash table entries: 1024 (order: 0, 4096 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory available: 5564k/8192k RAM, 0k/0k ROM (1518k kernel code, 1020k data)
Mount-cache hash table entries: 512
NET: Registered protocol family 16
SCSI subsystem initialized
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 1024 (order: 0, 4096 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
Serial: JTAG UART driver $Revision: 1.1 $
ttyJ0 at MMIO 0x81004000 (irq = 1) is a jtag_uart
dm9000 Ethernet Driver
eth%d: Invalid ethernet MAC address.  Please set using ifconfig
eth0: dm9000 at 80900090,80900094 IRQ 8 MAC: 00:00:00:00:00:00
isp1362-hcd isp1362-hcd: ISP1362 Host Controller
isp1362-hcd isp1362-hcd: new USB bus registered, assigned bus number 1
isp1362_hc_reset:
Clock not ready after 20ms
isp1362_hc_start:
isp1362-hcd isp1362-hcd: ISP1362 Memory usage:
isp1362-hcd isp1362-hcd:  ISTL:    2 *  256:      512 @ $0000:$0100
isp1362-hcd isp1362-hcd:  INTL:  16 * ( 64+8):  1152 @ $0200
isp1362-hcd isp1362-hcd:  ATL :  32 * ( 64+8):  2304 @ $0680
isp1362-hcd isp1362-hcd:  USED/FREE:  3968      128[/b]
isp1362_hc_reset:
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19676)
--- Quote End ---
[/b]
--- Quote End ---
Hi , kael
I met same problem.
You need recomplied DE2_NET project again.
Faye
The messages
isp1362_hc_reset:
appear since the 2.6.17 kernel driver,
the reason is that the reset function is now called and was not with 2.6.11 kernel driver.
It does not matter.
Why there is a problem with the clock check on De2 Brd needs investigation.
--- Quote Start ---
originally posted by faye@Nov 29 2006, 06:46 AM
hi , kael
i met same problem.
you need recomplied de2_net project again.
regards
faye
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19685)
--- quote end ---
--- Quote End ---
Do you mean simply recomple the DE2_NET project, or does something need to be reconfigured before recompiling?
Thanks for the quick feedback.
Hello everyone and thanks for your replies.
Going off what Faye suggested, I found the CD that came with the board that has all of the demonstrations mentioned in:
http://nioswiki.jot.com/wikihome/operating...s/tryoutuclinux (http://nioswiki.jot.com/wikihome/operating...s/tryoutuclinux
I used the DE2_NET.sof from the CD and it works just fine! It seems there is a problem with the file posted in the wiki.
Thanks again.
is there anyone who knows to do same thing on Windows?
