12745 Discussions
Uclinux-unrecognized instruction initda
Hi everyone,
I'm trying to build Uclinux on kit Cylone II DE II. I followed the instructions from this http://www.alterawiki.com/wiki/installnios2linux
I almost finish this; however, when I execute the "make" command
cd uClinux-distmake menuconfig*make vendor_hwselect SYSPTF=<path to your system ptf>makeI'm stucked at this error:
{standard input}: Assembler messages:
{standard input}:365: Error: unrecognised instruction initda
make[3]: *** [arch/nios2/mm/memory.o] Error 1
make[2]: *** [arch/nios2/mm] Error 2
make[1]: *** [sub-make] Error 2
make[1]: Leaving directory `/root/nios2-linux/linux-2.6'
make: *** [linux] Error 1
I've been battling this for several days, anyone know the answer ?. Thank you so much.
--- Quote Start ---
--- Quote End ---
Maybe, your compiler does not support the instruction 'initda'. Can you rewrite it by 'initd' ?
Kazu
