Hi Guys
I am trying to run the count_binary system. I am unable to find the following library file altera_avalon_pio_regs.h That's why my project does not build.. please helpLink Copied
--- Quote Start --- originally posted by napster@Jan 16 2007, 05:50 PM hi guys
i am trying to run the count_binary system. i am unable to find the following library file
that's why my project does not build..
please help
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20624)
--- quote end ---
--- Quote End --- If you use the IDE (which I recommend, initially), then this shouldn't be a problem. The example should build, no problem, on a variety of Altera designs. Cheers, - slacker
The problem was solved... the problem was I was using the DE2_PIO and the count_binary needs the pio under the other components!!!
Thanks a lot!!!!!!
