Using Library
Hi everbody,
i tried to add an Library to my Project.
But i doesnt works... But why ?
What i do :
I Add the Libray to the Files.
Then i open the Properties in the Project goto "C/C++ - Build"
the to the "Linker/Genreal" and Add my Library.
Now Compiling -> Works
The Linking -> Not Work.:mad:
The Linker says
Linking Test.elf...
/cygdrive/c/altera/72/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/bin/ld: cannot find -lC:/NIOS2/Test/workspace/Test/lib/lib.a
collect2: ld returned 1 exit status
make: *** [Test.elf] Error 1
Build completed in 216.674 seconds
I hope somebody can help me....
Thanks everbody.
Tobias
Within your application build properties, you can add the linker data which includes the name of the library and the path.
Hope that will help...
The library name should be just the name without any extension.
The path should be the location where the library.a is located.
