Hi everbody,
i tried to add an Library to my Project. But i doesnt works... But why ? What i do : I Add the Libray to the Files. Then i open the Properties in the Project goto "C/C++ - Build" the to the "Linker/Genreal" and Add my Library. Now Compiling -> Works The Linking -> Not Work.:mad: The Linker says Linking Test.elf... /cygdrive/c/altera/72/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/bin/ld: cannot find -lC:/NIOS2/Test/workspace/Test/lib/lib.a collect2: ld returned 1 exit status make: *** [Test.elf] Error 1 Build completed in 216.674 seconds I hope somebody can help me.... Thanks everbody. TobiasLink Copied
Within your application build properties, you can add the linker data which includes the name of the library and the path.
Hope that will help...- Mark as New
The library name should be just the name without any extension.
The path should be the location where the library.a is located.
