Using MACRO
I'd like to program NIOS II like plc language "Structured Text " and
in my future i want to create system based on fpga and NIOS II that
allows me to write accessing memory and pheriperal like this
For example , i want to access to my image input and memory :
IF (I2.0==true) and (M5.5==true)
OUT10.5=true;
It's possible , writing macro and structure or onion , to obtain like i want ?
Obvios i must to include header file (.h)
Thanks for information
Walter
* "Hello plc" example.
* This example works on cyclone dev board
# include <stdio.h># include "system.h"# include "altera_avalon_pio_regs.h"
# define BYTE alt_u8# define WORD alt_u16# define DWORD alt_u32
# define BIT0 0x01# define BIT1 0x02# define BIT2 0x04# define BIT3 0x08# define BIT4 0x10# define BIT5 0x20# define BIT6 0x40# define BIT7 0x80
# define BIT8 0x0100# define BIT9 0x0200# define BIT10 0x0400# define BIT11 0x0800# define BIT12 0x1000# define BIT13 0x2000# define BIT14 0x4000# define BIT15 0x8000
# define PIO_WR(BASE,DATA) IOWR_ALTERA_AVALON_PIO_DATA((BASE),(DATA))# define PIO_RD(BASE) (IORD_ALTERA_AVALON_PIO_DATA((BASE)))
typedef union {
struct {
BYTE b0:1; // bit0
BYTE b1:1; // bit1
BYTE b2:1; // bit2
BYTE b3:1; // bit3
BYTE b4:1; // bit4
BYTE b5:1; // bit5
BYTE b6:1; // bit6
BYTE b7:1; // bit7
} bit;
BYTE val;
} IO;
IO in0,in1,out0;
void read_inputs(void);
void write_outputs(void);
int main()
int i;
printf("Hello from Nios II!\n");
while(1) {
read_inputs(); // read all inputs
// do plc stuff
out0.bit.b4=in0.bit.b0 ;
out0.bit.b5=in0.bit.b1 ;
out0.bit.b7=in0.bit.b0 & in0.bit.b1;
write_outputs(); // write all outputs
return 0;
void read_inputs(void) {
// negate that 1 means key pressed
in0.val=~PIO_RD(BUTTON_PIO_BASE);
void write_outputs(void) {
PIO_WR(LED_PIO_BASE,out0.val);
thanks for the interesting
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif
ciao
walter
