12747 Discussions
what's wrong with my code?compile error
below is my code ,very simple,I compile it in nios IDE,not SDK,but I have created SDK with sopc builder.which header I need ?where can I find it ? In some sample ,I see "include "excalibur.h"",but some tell me this header was used in SDK ,not IDE? DO I need this file?when I put this file ,compile cann't find it too!thank very much! help me !
# include <stdio.h># include "system.h"
int main()
na_timer1->np_timerperiodl = (short)(nasys_clock_freq & 0x0000ffff);
na_timer1->np_timerperiodh = (short)((nasys_clock_freq >> 16) & 0x0000ffff); // Set timer running, looping, no interrupts
na_timer1->np_timercontrol = np_timercontrol_start_mask+ np_timercontrol_cont_mask;
return 0;
make -s all
Compiling hello_world.c...
../hello_world.c: In function `main&#39;:
../hello_world.c:22: error: `na_timer1&#39; undeclared (first use in this function)
../hello_world.c:22: error: (Each undeclared identifier is reported only once
../hello_world.c:22: error: for each function it appears in.)
../hello_world.c:22: error: `nasys_clock_freq&#39; undeclared (first use in this function)
../hello_world.c:24: error: `np_timercontrol_start_mask&#39; undeclared (first use in this function)
../hello_world.c:24: error: `np_timercontrol_cont_mask&#39; undeclared (first use in this function)
make: *** [obj/hello_world.o] Error 1
Build completed
You are trying to mix the legacy SDK with the HAL (the software environment used by the IDE). This won&#39;t work.
The legacy SDK is not recommended for new projects.
I suggest you look at using the macros within components/altera_avalon_timer/inc/altera_avalon_timer_regs.h which is the HAL way to do things.
One more hint - if you are accessing the timer directly then you will need to start from an alt_main project as otherwise the HAL timer code will get in your way.
wombat ,thank you very much!
