VSCode Nios II command shell
qwk000
Has anyone tried and successfully enabled the Nios II Command Shell in Microsoft VSCode?
qwk000
I'm back!  Ok, to get the build environment (somewhat) integrated into VSCode, the secret is: Launch "code" from the Nios II Command Shell. That way, the path to "make" is known, and the right shell is launched during the build.
I think these items are needed in the settings for the "Makefile Tools" extension:
If the Makefile is not in the root of the folder, you'll have to tell the extension where it is using setting in the same section shown in the image above.
Now I have clickable links:
qwk000
That was pretty easy. Just needed better googling skils.
Next, anyone know how to integrate the "make" build into VSCode? Just the simple terminal integration doesn't provide clickable links to errors/warnings.
qwk000
qwk000
To get Intellisense working decently in VSCode, in addition to the steps above, follow these steps:
Configure IntelliSense for C++ cross-compilation (visualstudio.com)
GavinPaterson
Hi qwk000,
Apologies for bothering you but thought you might have some advice regards debugging in VScode? I am able to "Build target" using "code ." from my NIOS II command shell in Microsoft Windows 11.  I am unable however to run or debug my application though as I see there are "No launch targets identified"
I receive a message "Cannot 'debug' because there is no launch configuration set and the list of launch targets is empty. Double check the makefile configuration and the build target."
I have checked in the "settings.json" and have "launch.json" populated as follows:
    "version": "0.2.0",
    "configurations": [
        "name": "Myapp",
        "type": "cppdbg",
        "request": "launch",
        "program": "${workspaceFolder}/Myapp.elf",
        "args": [],
        "stopAtEntry": true,
        "cwd": "${workspaceFolder}",
        "MIMode": "gdb",
        "miDebuggerServerAddress": "localhost:2334",
        "miDebuggerPath": "/mnt/c/intelFPGA_lite/22.1std/nios2eds/bin/gnu/H-x86_64-mingw32/bin/nios2-elf-gdb.exe",
        "debugServerPath": "/mnt/c/intelFPGA_lite/22.1std/quartus/bin64/nios2-gdb-server.exe",
        "debugServerArgs": "--tcpport 2334 --reset-target --tcppersist",
for some reason the build executable isn't getting picked up when I go to launch? Do you have any ideas/advice?
G5P7
This configuration works for me:
It's based on Zapho's answer to a related question:
N.B. this particular solution also needs the Command Variable extension that you can read about further here
I have the following in the User's settings.json :
"makefile.configurations": [
"name": "Nios-user-settings",
"buildLog": "",
"makeArgs": [],
"makeDirectory": "/home/user/fpga_projects/hw_proj/software/sw_proj",
"makefilePath": "/home/user/fpga_projects/hw_proj/software/sw_proj/Makefile",
"problemMatchers": [],
"postConfigureArgs": [],
"preConfigureArgs": [],
"makePath": "/home/user/intelFPGA_lite/21.1/quartus/linux64/gnu/make",
This is all that's needed to use the Makefile-Tools extension to build the software project using make. All that's necessary is to be able to build the "current target"
The following can then be added to the project's .vscode/launch.json:
"configurations": [
"name": "(nios-gdb) Launch",
"type": "cppdbg",
"program": "/home/user/fpga_projects/hw_proj/software/sw_proj/program.elf",
"args": [],
"environment": [
"name": "CWD",
"value": "${workspaceFolder}"
"name": "PATH",
"value": "/home/user/intelFPGA_lite/21.1/nios2eds/bin/gnu/H-x86_64-pc-linux-gnu/scripts"
"name": "PWD",
"externalConsole": false,
"MIMode": "gdb",
"setupCommands": [
"description": "Enable pretty-printing for gdb",
"text": "-enable-pretty-printing",
"ignoreFailures": true
"description": "Set Disassembly Flavor to Intel",
"text": "-gdb-set disassembly-flavor intel",
"miDebuggerServerAddress": "localhost:${input:randomPort}",
"miDebuggerPath": "/home/user/intelFPGA_lite/21.1/nios2eds/bin/gnu/H-x86_64-pc-linux-gnu/bin/nios2-elf-gdb",
"debugServerPath": "/home/user/intelFPGA_lite/21.1/quartus/bin/nios2-gdb-server",
"debugServerArgs": "--tcpport ${input:rememberRandomPort} --reset-target --tcptimeout 5",
"inputs": [
"id": "randomPort",
"type": "command",
"command": "extension.commandvariable.number",
"args": {
"name": "randomPort",
"range": [1500, 60000],
"random": true,
"uniqueCount": 10
"id": "rememberRandomPort",
"type": "command",
"command": "extension.commandvariable.remember",
"args": { "key": "number-randomPort" }
The vscode built-in Run & Debug button on the left hand panel (Ctrl + Shift + D)  can then be used to Debug the application.
This doesn't allow all functionality of Eclipse but allows for making and debugging the software project..
There's some further reading here
It's not clear if there's likely to be more configurability in the Makefile Tools soon.
EBERLAZARE_I_Intel
May I know your windows version you're working on?
qwk000
EBERLAZARE_I_Intel
May I know also the Quartus/Nios II version that you used?
Also, do you have any further questions/help needed?
qwk000
Quartus Prime Version 18.1.0 Build 625 Standard Edition
No further assistance needed.
EBERLAZARE_I_Intel
Thanks for the update and the information.
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or you may also select your own best answer for other user's experience or rate 4/5 survey.
