12747 Discussions
We use in the lab Altera Monitor Program to download the NIOSII Processor on the FPGA chip and to compile the C-language codes. is there any way or simulator to do the experiments during lockdown without the Chip?
MZabi1
EricMunYew_C_Intel
Hi, Zabin
You can run Nios II RTL simulation to verify your design without downloading to FPGA.
Platform Designer will allow you to generate a testbench and a tcl file for simulation using ModelSim. Nios SBT will allow you to generate .mif files (your C code) for memory initialization.
You may refer to page 433 to 439 of below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/nios2/edh_ed_handbook.pdf
https://www.intel.com/content/www/us/en/programmable/support/support-resources/design-examples/intellectual-property/embedded/nios-ii/exm-simulating-niosii.html
Eric
EricMunYew_C_Intel
Hi, Zabin
The method or link I listed below will work for Nios simulation (with application C code).
Do you have anymore question ? can we close the case ?
Eric
