12748 Discussions
What can I do for 'Main Optimizer failed' error in Intel HLS?
My component has two stream in inputs and one stream out output.
The two inputs pass through the Shift register and perform multiply operations between the elements.
x86 execution is not a problem. An error such as the following occurs when executing build.bat test-fpga.
"Instruction does not dominate all users!"
One stream in is a blocking read, and the other stream in is a non-blocking read.
Changing both data to non-blocking causes the same error.
Shift register has no errors, and errors occur when multiplying the elements.
The data type is ac_fixed, and is an operation of 8bit and 1bit.
I uses Quartus 17.1 version. What can I do?
Can you share the command prompt log, .cpp & .bat files?
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
Dear Mr. Anand
I am sorry. I can't share any files because of our company policy.
But I add pseudo code. build.bat is changed only cpp filename and -ghdl option for test-fpga.
# include <>
typedef ac_fixed<8,8,false> fixed8;
typedef ac_fixed<1,1,false> fixed1;
typedef ac_fixed<10,10,false> fixed10;
component void func(stream_in<fixed8> a, stream_in<fixed1> b, stream_out<fixed10> c) {
hls_init_on_reset static fixed8 d[xx];
hls_init_on_reset static fixed1 e[xx];
for (){
// Non blocking read1
bool success = false;
fixed8 data = a.tryRead(success);
if (success) {
//Shift register
# pragma unroll
for ...
d[] = data;
// Non blocking read2
bool success1 = false;
fixed8 data1 = b.tryRead(success1);
if (success1) {
//Shift register
# pragma unroll
for ...
e[] = data1;
//--------------- The following makes error ----------------
fixed10 m = d[] *e[];
c.write(out);
int main() {
//Generate stream in data and buffer
// Invoke component
return 0;
That's all. What can I do?
