What's the problem of flash
hi,everyone.
I confront the problem that: the flash can work sometimes.
The flash is AM29LV641DH-90
When I use flashprogrammer flashdown elf,it can flash down sometimes like :
--------------------------------# ! /bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.#
cd I:/WOEPCS/hello_world_0/Debug
# Creating .flash file for the FPGA configuration
$SOPC_KIT_NIOS2/bin/sof2flash --epcs --input=I:/WOEPCS/WOEPCS.sof --output=WOEPC
S.flash
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert --device=EPCS64 --option=WOEPCS
.opt I:/WOEPCS/WOEPCS.sof WOEPCS.pof
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
Info: Processing ended: Mon Oct 23 19:40:15 2006
Info: Elapsed time: 00:00:02
Info: Command: quartus_cpf --no_banner --convert WOEPCS.pof WOEPCS.rpd
Info: Processing ended: Mon Oct 23 19:40:17 2006
Info: Elapsed time: 00:00:01
# Programming flash with the FPGA configuration
$SOPC_KIT_NIOS2/bin/nios2-flash-programmer --cable='ByteBlasterMV [LPT1]' --devi
ce=1 --epcs --base=0x00000000 WOEPCS.flash
Using cable "ByteBlasterMV [LPT1]", device 1, instance 0x00
Resetting and pausing target processor: OK
: Checksumming existing contents
00000000 : Verifying existing contents
00008000 : Verifying existing contents
00010000 : Verifying existing contents
00000000 : Reading existing contents
00008000 : Reading existing contents
00010000 : Reading existing contents
Checksummed/read 96kB in 6.6s
00000000 ( 0%): Erasing
00008000 (33%): Erasing
00010000 (66%): Erasing
Erased 96kB in 2.8s (34.2kB/s)
00000000 ( 0%): Programming
00008000 (33%): Programming
00010000 (66%): Programming
Programmed 76KB +20KB in 3.9s (24.6KB/s)
Did not attempt to verify device contents
Leaving target processor paused
# Creating .flash file for the project
$SOPC_KIT_NIOS2/bin/elf2flash --base=0x00800000 --end=0xbfffff --reset=0x0 --inp
ut=hello_world_0.elf --output=cfi_flash_0.flash --boot=$SOPC_KIT_NIOS2/component
s/altera_nios2/boot_loader_cfi.srec
# Programming flash with the project
ce=1 --base=0x00800000 cfi_flash_0.flash
Checksummed/read 16kB in 1.1s
Erased 64kB in 0.3s (213.3kB/s)
Programmed 49KB +15KB in 3.5s (18.2KB/s)
Device contents checksummed OK
But sometimes(and almost) ,it appear like this:
NO CFI Table found at 0x800000
The step I create my board description is that:I use protel 2004 to generate wirelist formate file.then In the SOPC new description,.........
How can I know whether the flash is OK or NOT.Is flash easy to broke.
Could anyone give me some advice to findout where is wrong.Thanks.
Best wishes!
