My board has a SRAM on it. So I tried to use it in NIOS II.
From ftp://ftp.altera.com/up/pub/university_program_ip_cores/90 , I got a SRAM_Controller code to interface the SRAM to Avalon bus. However, when I try to put my code to SRAM by setting reset&exception memory location, I can not find this memory in the drop-down list. On-chip SRAM and CFI FLASH can be displayed in the drop-down list. Can anyone help to explain how I can put my software code to the SRAM directly? Thanks.Link Copied
Did you remember to give the nios's instruction port access to the SRAM?
(you'll need data port acces as well ....)- Mark as New
If above does not help, make sure that in the .tcl-file of the component there is following line:
set_interface_property avalon_slave_xxx isMemoryDevice true- Mark as New
--- Quote Start --- Did you remember to give the nios's instruction port access to the SRAM? (you'll need data port acces as well ....) --- Quote End --- Thanks. Both instruction & data port are connected, but the problem still exits.
--- Quote Start --- If above does not help, make sure that in the .tcl-file of the component there is following line: set_interface_property avalon_slave_xxx isMemoryDevice true --- Quote End --- Thanks. This method works. Now I can run download software to SRAM and run it.
Topic Options
