Writing to SRAM
Hi everyone,
Does anyone have a tutorial that shows me how to write to Memory using SOPC?
--- Quote Start ---
--- Quote End ---
This one shows you how to use on-chip SRAM.
http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial
The PDF has an appendix with links to Altera's online resources.
For external memory interfaces you can read:
http://www.altera.com/literature/lit-external-memory-interface.jsp
For external SRAM, look at the tri-state bridge component.
Cheers,
Dave
Thanks Dave, you are the best.
In your opnion, what is the best way to write to SRAM on DE2 board?
Here is what I did. I established an RS232 commuincation between PC and the Board and It was great. However, the RS232 program such as HyperTerminal, PuTTY, and Tera Time are not realiable! Sometimes I can transfer a whole file o.k and other times I can't ?!!!
what is your advice? Please help.
Mona
Many Thanks :)
--- Quote Start ---
--- Quote End ---
Can you confirm that its the PC that is the problem? Perhaps it is the FPGA. If the RS232 interface does not implement the CTS/RTS handshake wires, then you could be overrunning your buffers in the FPGA. What is processing your RS232 data; is it a state machine, or a NIOS II processor?
The tutorial I linked to shows how to use the JTAG interface to implement access to the board. Using master_write_memory and master_read_memory within system console, you can get about 600kbps (73kB/s) transfer rate.
Cheers,
Dave
--- Quote Start ---
Cheers,
Dave
--- Quote End ---
Hi Dave,
Thanks again for your help.
Well, I am using a State Machine not NIOS. This is why I want to switch to NIOS maybe I will be get a better luck. I am not implementing any handshake protocol !
I am just using an 115200 8N1 with no applied protocol! Is this bad?
Here is my code (its a code I got from the net :oops: )
module async_receiver(clk, RxD, RxD_data_ready, RxD_data, RxD_endofpacket, RxD_idle);
input clk, RxD;
output RxD_data_ready; // onc clock pulse when RxD_data is valid
output [7:0] RxD_data;
parameter ClkFrequency = 100000000; // 50MHz
//parameter ClkFrequency = 27000000; // 27MHz
parameter Baud = 115200;
//parameter Baud = 9600;
// We also detect if a gap occurs in the received stream of characters
// That can be useful if multiple characters are sent in burst
// so that multiple characters can be treated as a "packet"
output RxD_endofpacket; // one clock pulse, when no more data is received (RxD_idle is going high)
output RxD_idle; // no data is being received
// Baud generator (we use 8 times oversampling)
parameter Baud8 = Baud*8;
parameter Baud8GeneratorAccWidth = 16;
parameter Baud8GeneratorInc = ((Baud8<<(Baud8GeneratorAccWidth-7))+(ClkFrequency>>8))/(ClkFrequency>>7);
reg [Baud8GeneratorAccWidth:0] Baud8GeneratorAcc;
always @(posedge clk) Baud8GeneratorAcc <= Baud8GeneratorAcc[Baud8GeneratorAccWidth-1:0] + Baud8GeneratorInc;
wire Baud8Tick = Baud8GeneratorAcc[Baud8GeneratorAccWidth];
reg [1:0] RxD_sync_inv;
always @(posedge clk) if(Baud8Tick) RxD_sync_inv <= {RxD_sync_inv[0], ~RxD};
// we invert RxD, so that the idle becomes "0", to prevent a phantom character to be received at startup
reg [1:0] RxD_cnt_inv;
reg RxD_bit_inv;
if(Baud8Tick)
begin
if( RxD_sync_inv[1] && RxD_cnt_inv!=2'b11) RxD_cnt_inv <= RxD_cnt_inv + 1;
else
if(~RxD_sync_inv[1] && RxD_cnt_inv!=2'b00) RxD_cnt_inv <= RxD_cnt_inv - 1;
if(RxD_cnt_inv==2'b00) RxD_bit_inv <= 0;
else
if(RxD_cnt_inv==2'b11) RxD_bit_inv <= 1;
end
reg [3:0] state;
reg [3:0] bit_spacing;
// "next_bit" controls when the data sampling occurs
// depending on how noisy the RxD is, different values might work better
// with a clean connection, values from 8 to 11 work
wire next_bit = (bit_spacing==10);
if(state==0)
bit_spacing <= 0;
else
if(Baud8Tick)
bit_spacing <= {bit_spacing[2:0] + 1} | {bit_spacing[3], 3'b000};
if(Baud8Tick)
case(state)
4'b0000: if(RxD_bit_inv) state <= 4'b1000; // start bit found?
4'b1000: if(next_bit) state <= 4'b1001; // bit 0
4'b1001: if(next_bit) state <= 4'b1010; // bit 1
4'b1010: if(next_bit) state <= 4'b1011; // bit 2
4'b1011: if(next_bit) state <= 4'b1100; // bit 3
4'b1100: if(next_bit) state <= 4'b1101; // bit 4
4'b1101: if(next_bit) state <= 4'b1110; // bit 5
4'b1110: if(next_bit) state <= 4'b1111; // bit 6
4'b1111: if(next_bit) state <= 4'b0001; // bit 7
4'b0001: if(next_bit) state <= 4'b0000; // stop bit
default: state <= 4'b0000;
endcase
reg [7:0] RxD_data;
if(Baud8Tick && next_bit && state[3]) RxD_data <= {~RxD_bit_inv, RxD_data[7:1]};
reg RxD_data_ready, RxD_data_error;
begin
RxD_data_ready <= (Baud8Tick && next_bit && state==4'b0001 && ~RxD_bit_inv); // ready only if the stop bit is received
RxD_data_error <= (Baud8Tick && next_bit && state==4'b0001 && RxD_bit_inv); // error if the stop bit is not received
end
reg [4:0] gap_count;
always @(posedge clk) if (state!=0) gap_count<=0; else if(Baud8Tick & ~gap_count[4]) gap_count <= gap_count + 1;
assign RxD_idle = gap_count[4];
reg RxD_endofpacket; always @(posedge clk) RxD_endofpacket <= Baud8Tick & (gap_count==15);
endmodule
Pleasae let me know
--- Quote Start ---
--- Quote End ---
That should work fine.
--- Quote Start ---
--- Quote End ---
Its very difficult to read code and see bugs (other than the obvious). You should really create a simulation and see if the code responds correctly to serial characters on its input and generates them on its output.
Cheers,
Dave
--- Quote Start ---
Cheers,
Dave
--- Quote End ---
Thanks Dave, you are the best :)
I have tested the transfer with few characters, it works perfect. The problem is when I transfer a big file. Sometimes, it works fine and transfer 100% of the file. Sometimes, it transfer 80% of the file?!!
so I think I want to switch to Nios, let me try the tutorial link you sent me and get back to you on this.
Mona
