12748 Discussions
a weird issue with wrctl instruction
Hi all,
I encountered a weird issue that I enabled one PIO interrupt by using:
alt_irq_register(STROBE_PIO_IRQ, edge_capture_ptr, command_receive_interrupt);
STROBE_PIO_IRQ equals to 3
after calling alt_irq_register, the ienable register doesn't change its value to enable STROBE_PIO_IRQ.
So, I tried to find what was the problem, then I step into alt_irq_register routine, and found the problem, see the following assembly code:
wrctl ienable, r2
before excuting this instruction, I can see that the value stored in r2 register is 0x1f and ienable = 0x17, but after excuting this instruction the ienable remained the original value of 0x17.
It's a very weird problem, anyone help?
best regards,
David
