12748 Discussions
adc alt_sys_init.c build error
SeanAB
Quartus 21.1
MAX 10 10M08
Created an NIOS II with ADC, PLL, JTAG UART, TIMER. design builds fine in Quartus.
Creating an application in Eclipse with the hello_world_small template. Build the project and I am getting errors in alt_sys_inti.c that I cannot figure out how to fix:
in file included from alt_sys_init.c:65:
alt_sys_init.c:75:31: error: 'MODULAR_ADC0_NAME' undeclared here (not in a function)
75 | ALTERA_MODULAR_ADC_INSTANCE ( MODULAR_ADC0, modular_adc0);
./drivers/inc/altera_modular_adc.h:97:5: note: in definition of macro 'ALTERA_MODULAR_ADC_INSTANCE'
97 | name##_NAME, \
alt_sys_init.c:75:31: error: 'MODULAR_ADC0_DUAL_ADC_MODE' undeclared here (not in a function); did you mean 'MODULAR_ADC0_SEQUENCER_CSR_DUAL_ADC_MODE'?
./drivers/inc/altera_modular_adc.h:110:4: note: in definition of macro 'ALTERA_MODULAR_ADC_INSTANCE'
110 | name##_DUAL_ADC_MODE \
alt_sys_init.c: In function 'alt_sys_init':
alt_sys_init.c:101:31: error: 'MODULAR_ADC0_IRQ_INTERRUPT_CONTROLLER_ID' undeclared (first use in this function); did you mean 'PLLFORADC0_IRQ_INTERRUPT_CONTROLLER_ID'?
101 | ALTERA_MODULAR_ADC_INIT ( MODULAR_ADC0, modular_adc0);
./drivers/inc/altera_modular_adc.h:119:32: note: in definition of macro 'ALTERA_MODULAR_ADC_INIT'
119 | altera_modular_adc_init(&dev, name##_IRQ_INTERRUPT_CONTROLLER_ID, name##_IRQ);
alt_sys_init.c:101:31: note: each undeclared identifier is reported only once for each function it appears in
alt_sys_init.c:101:31: error: 'MODULAR_ADC0_IRQ' undeclared (first use in this function)
./drivers/inc/altera_modular_adc.h:119:68: note: in definition of macro 'ALTERA_MODULAR_ADC_INIT'
Makefile:583: recipe for target 'obj/alt_sys_init.o' failed
make: *** [obj/alt_sys_init.o] Error 1
Was there a step I could have missed Platform Builder?
hareesh
Hi @SeanAB ,
it's a software bug, I will raise ticket about this issue. if i get any alternate solution i will forward to you.
if you don't have any quires I'll close the case. please confirm
 If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
hareesh
Hi SeanAB,
I tried duplicating the issue but its not reproducible in our system. What is the Quartus edition you are using. Also Can you please share platform design and SOPC information file.
Kind regards,
SeanAB
Quartus Prime Lite Ver 21.1.0 Build 842 10/21/21 - Windows 10 Host system
Eclipse Mars.2 rel 4.5.2
After spending a few more hours digging into the code, it appears the project wizard doesn't set up everything correctly.  Two corrections need to be made to get the application to build.
1. altera_modular_adc.h contains the following, form lines 92 to lines 120:
#define ALTERA_MODULAR_ADC_INSTANCE(name, dev) \
static alt_modular_adc_dev dev = \
ALT_LLIST_ENTRY, \
name##_NAME, \
NULL, \
NULL, \
NULL, \
NULL, \
NULL, \
NULL, \
NULL, \
NULL, \
NULL, \
0, \
0, \
* The macro ALTERA_MODULAR_ADC_INIT is called by the auto-generated function
* alt_sys_init() to initialize a given device instance.
#define ALTERA_MODULAR_ADC_INIT(name, dev) \
After going through system.h, I modified this file to add the correct constant names.
ALT_LLIST_ENTRY, \
name##_SEQUENCER_CSR_NAME, \
NULL, \
NULL, \
NULL, \
NULL, \
NULL, \
NULL, \
NULL, \
NULL, \
NULL, \
0, \
0, \
name##_SEQUENCER_CSR_DUAL_ADC_MODE \
altera_modular_adc_init(&dev, name##_SAMPLE_STORE_CSR_IRQ_INTERRUPT_CONTROLLER_ID, name##_SAMPLE_STORE_CSR_IRQ);
2. The second problem is that the application doesn't resolve the paths to all the libraries in the BSP. I modified the application's makefile to include the following at line 131:
APP_INCLUDE_DIRS += ../anotherADC_bsp/
APP_INCLUDE_DIRS += ../anotherADC_bsp/drivers/inc/
Once these corrections are made the application builds successfully. Attached is the SPOC information file.
hareesh
Can please share your platform design screen shot
SeanAB
Here is the screen shot.
Thierry29
the same problem exists under Quartus Prime Lite 21.1.1 in Linux edition.
Regards.
hareesh
Hi @SeanAB ,
SeanAB
@hareesh
Thank you for looking into this. Yes, this closes the case.
