boa problems
Please see attachment
hi zzh
i will help until the resolution of your problem if God wants it http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
if i understand well, u can access the index.html but cgi dont work ?
if u access the index.html it means that boa works.
but when I took a look to your html code, I remarque that u use POST methode for FORMs, I hope u use GET methode cause it&#39;s easier, until we see were is the problem
Hi,sdhnian
Thank you for your advice.
yeah,The boa work ,but cgi program doesn&#39;t .
That is the problem.
"Get" method don&#39;t change the "HTTP 404 not found " error.
I tried.
hi zzh
don&#39;t give up, try this simple example :
************* html code : index.html******************
<FORM method="get" ACTION="mult.cgi" >
Please specify the multiplicands:
<INPUT NAME="m" SIZE="5">
<INPUT NAME="n" SIZE="5">
<INPUT TYPE="SUBMIT" VALUE="Multiply!">
</FORM>
************** cgi code : mult.c******************
# include <stdio.h># include <stdlib.h>
int main(void)
char *data;
long m,n;
printf("%s%c%c\n",
"Content-Type:text/html;charset=iso-8859-1",13,10);
printf("<TITLE>Multiplication results</TITLE>\n");
printf("<H3>Multiplication results</H3>\n");
data = getenv("QUERY_STRING");
if(data == NULL)
printf("
Error! Error in passing data from form to script.");
else if(sscanf(data,"m=%ld&n=%ld",&m,&n)!=2)
printf("
Error! Invalid data. Data must be numeric.");
else
printf("
The product of %ld and %ld is %ld.",m,n,m*n);
return 0;
******************** Makefile : Makefile***********************# # configurable options# - set DEBUG = 1 to turn on debugging support#
DEBUG = 1
PROJ_NAME = mult
INSTALL_DIR =
PROGS := $(PROJ_NAME).exe
CFLAGS +=
# # You should not need to modify anything beyond this point#
TOPDIR = .
include ./Rules.mak
ifeq &#39;$(DEBUG)&#39; &#39;1&#39;
PROGS += $(PROGS:.exe=.gdb)
endif
all: $(PROGS)
.PHONY: clean
clean:
-rm -f *.[oad] *.elf *.gdb *.bin *.exe
.PHONY: install
install: all
ifeq "$(INSTALL_DIR)" ""
$(error No installation directory specified)
endif
mkdir -p $(INSTALL_DIR)/bin
install -v $(filter %.exe, $(PROGS)) $(INSTALL_DIR)/bin
steps to follow :
--> create a new uclinux application
--> add "mult.c" and "Makefile" to project
--> right click on project :
-- creat make target --> yes
-- build make target
--> if compilation success it will create a multi.exe
--> add "index.html" and "mult.exe" to httpd derictory on file system
--> rename "mult.exe" by "mult.cgi"
and go ! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
Hi.
I will try tomorrow.hehe.
Thank you very much!!!!!!!! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
Hi,shhnain.
OK it works . Thank you very much!! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
but i am coufused.
ScriptAlias: /cgi-bin/ /home/httpd/cgi-bin/
why in the index.html , the action="/cgi-bin/mult.cgi" is not work.
of course we place mult.cgi to /home/httpd/cgi-bin/.
Does we must place cgi programs into /home/httpd ?
--- Quote Start ---
originally posted by zzh@May 5 2006, 03:32 AM
hi,shhnain.
ok it works . thank you very much!! http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/biggrin.gif
but  i am coufused.
scriptalias: /cgi-bin/  /home/httpd/cgi-bin/
does we must place cgi programs into /home/httpd ?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15068)
--- quote end ---
--- Quote End ---
hi, thanks to GOD, it works
cgi files can be placed at any folder but I remarque that u use action="/cgi-bin/mult.cgi"
I think u have to try : action="cgi-bin/mult.cgi" because cgi-bin is directly under /home/httpd
good luck http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
