Annonces
12748 Discussions
build kernel errors (follows UClinuxDist in Wiki)
Contributeur émérite II
1 611 Visites
hi. i am a beginner on uclinux and i followed the UClinuxDist to build the uclinux kernel, but it turned out some errors.
>make vendor_hwselect SYSPTF=~/download/HW/system_0.ptf
>make romfs
make[1]: Leaving directory `/home/echo/download/uClinux-dist/lib'
make[1]: Entering directory `/home/echo/download/uClinux-dist/include'
make[1]: Nothing to be done for `romfs'.
make[1]: Leaving directory `/home/echo/download/uClinux-dist/include'
make[1]: Entering directory `/home/echo/download/uClinux-dist/user'
for i in boa busybox cgi_generic dhcpcd-new ftp ftpd games inetd init ntp sash telnetd /home/echo/download/uClinux-dist/prop ; do
[ ! -d $i ] || make -C $i romfs || exit $? ;
done
make[2]: Entering directory `/home/echo/download/uClinux-dist/user/boa'
for i in src ; do make -C $i romfs || exit ; done
make[3]: Entering directory `/home/echo/download/uClinux-dist/user/boa/src'
romfs-inst.sh /bin/boa
cp: can't confirm ‘boa’: No such file or directory
make[3]: *** [romfs] error 1
make[3]: Leaving directory `/home/echo/download/uClinux-dist/user/boa/src'
make[2]: *** [romfs] error 2
make[2]: Leaving directory `/home/echo/download/uClinux-dist/user/boa'
make[1]: *** [romfs] error 2
make[1]: Leaving directory `/home/echo/download/uClinux-dist/user'
make: *** [romfs.subdirs] error 1
>make
CHK include/linux/version.h
CHK include/linux/utsrelease.h
CHK include/linux/compile.h
GEN usr/initramfs_data.cpio.gz
/home/echo/download/uClinux-dist/linux-2.6.x/scripts/gen_initramfs_list.sh: line 137: gawk:command not found
Unrecognized dir format '/init 777 1000 1000' line 42
make[2]: *** [usr/initramfs_data.cpio.gz] error 255
make[1]: *** [usr] error 2
make[1]: Leaving directory `/home/echo/download/uClinux-dist/linux-2.6.x'
make: *** [linux] error 1
>make
>make linux image
make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- -j1 -C linux-2.6.x zImage || exit 1
no emulation specific options.
make[1]: Entering directory `/home/echo/download/uClinux-dist/linux-2.6.x'
CHK include/nios2_system.h
perl -I/home/echo/download/uClinux-dist/linux-2.6.x/arch/nios2nommu/scripts /home/echo/download/uClinux-dist/linux-2.6.x/arch/nios2nommu/scripts/gen_nios2_system.h.pl cpu_0 sdram_0 cfi_flash_0 < /home/echo/download/HW/system_0.ptf > include/nios2_system.h.tmp; if [ -r include/nios2_system.h ] && cmp -s include/nios2_system.h include/nios2_system.h.tmp; then rm -f include/nios2_system.h.tmp; else echo &#39; UPD include/nios2_system.h&#39;; mv -f include/nios2_system.h.tmp include/nios2_system.h; fi
/home/echo/download/uClinux-dist/linux-2.6.x/scripts/gen_initramfs_list.sh: line 137: gawk&#65306;command not found
Unrecognized dir format &#39;/init 777 1000 1000&#39; line 42
make[1]: Leaving directory `/home/echo/download/uClinux-dist/linux-2.6.x&#39;
my ptf is from the wiki "system_0.ptf" and seclet Altera, nios2nommu, None Libc and default all settings, i did it step by step and i don&#39;t know why these errors happen and also don&#39;t know how to solve them.
so can any body help me?i will show great appreciation to you! thanks!
0 Compliments
5 Réponses
805 Visites
Check if you have the "gawk" command with,
which gawk
Or check if you have it in /usr/bin or /bin dir.
Which Linux distro do you use? have you installed devolopment packages?
If you are new to Linux, I would suggest CentOS 4.4.
0 Compliments
805 Visites
--- Quote Start ---
originally posted by hippo@Apr 4 2007, 09:28 AM
check if you have the "gawk" command with,
which gawk
or check if you have it in /usr/bin or /bin dir.
which linux distro do you use? have you installed devolopment packages?
if you are new to linux, i would suggest centos 4.4.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22799)
--- quote end ---
--- Quote End ---
i run the command "gawk --help", the terminal shows"command not found", and i have checked that there was no "gawk" in both /bin and /usr/bin dir.
i use ubuntu6.1 linux .
just now i build kernel again, but run "make romfs" after running "make", and finally i got the zImage file ,but there were still many problems as follows(after i run "make linux image") :
Unrecognized dir format &#39;/bin/cp 777 1000 1000&#39; line 9
Unrecognized dir format &#39;/bin/dd 777 1000 1000&#39; line 10
Unrecognized dir format &#39;/bin/mount 777 1000 1000&#39; line 11
Unrecognized dir format &#39;/bin/netstat 777 1000 1000&#39; line 12
Unrecognized dir format &#39;/bin/ping 777 1000 1000&#39; line 13
Unrecognized dir format &#39;/bin/rm 777 1000 1000&#39; line 14
Unrecognized dir format &#39;/usr/bin/ftpget 777 1000 1000&#39; line 59
Unrecognized dir format &#39;/usr/bin/ftpput 777 1000 1000&#39; line 60
Unrecognized dir format &#39;/usr/bin/telnet 777 1000 1000&#39; line 61
Unrecognized dir format &#39;/usr/bin/wget 777 1000 1000&#39; line 62
Unrecognized dir format &#39;/init 777 1000 1000&#39; line 66
Unrecognized dir format &#39;/sbin/ifconfig 777 1000 1000&#39; line 68
Unrecognized dir format &#39;/sbin/insmod 777 1000 1000&#39; line 69
Unrecognized dir format &#39;/sbin/lsmod 777 1000 1000&#39; line 70
Unrecognized dir format &#39;/sbin/modprobe 777 1000 1000&#39; line 71
Unrecognized dir format &#39;/sbin/rmmod 777 1000 1000&#39; line 72
Unrecognized dir format &#39;/sbin/route 777 1000 1000&#39; line 73
0 Compliments
805 Visites
You need gawk package, follow
https://help.ubuntu.com/6.10/ubuntu/desktopguide/c/apt.html (https://help.ubuntu.com/6.10/ubuntu/desktopguide/c/apt.html
If you are new to Linux, you should try CentOS 4.4 (but not 5.x) . Select the development tool package group, everything should be here.
0 Compliments
805 Visites
--- Quote Start ---
originally posted by hippo@Apr 4 2007, 08:53 PM
you need gawk package, follow
if you are new to linux, you should try centos 4.4 (but not 5.x) . select the development tool package group, everything should be here.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22820)
--- quote end ---
--- Quote End ---
thanks, hippo. i have solved it! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/laugh.gif
0 Compliments
805 Visites
--- Quote Start ---
which gawk
--- quote end ---
--- Quote End ---
I have it in /usr/bin dir,
but when i make romfs:
make[2]: Entering directory `/home/nios/download/uClinux-dist/user/boa&#39;
make[3]: Entering directory `/home/nios/download/uClinux-dist/user/boa/src&#39;
cp: stat‘boa’&#22833;&#36133;: &#27809;&#26377;&#37027;&#20010;&#25991;&#20214;&#25110;&#30446;&#24405;
make[3]: *** [romfs] &#38169;&#35823; 1
make[3]: Leaving directory `/home/nios/download/uClinux-dist/user/boa/src&#39;
make[2]: *** [romfs] &#38169;&#35823; 2
make[2]: Leaving directory `/home/nios/download/uClinux-dist/user/boa&#39;
make[1]: *** [romfs] &#38169;&#35823; 2
make[1]: Leaving directory `/home/nios/download/uClinux-dist/user&#39;
make: *** [romfs.subdirs] &#38169;&#35823; 1
0 Compliments
Répondre
