12748 Discussions
build kernel errors (follows UClinuxDist in Wiki)
hi. i am a beginner on uclinux and i followed the UClinuxDist to build the uclinux kernel, but it turned out some errors.
>make vendor_hwselect SYSPTF=~/download/HW/system_0.ptf
>make romfs
make[1]: Leaving directory `/home/echo/download/uClinux-dist/lib'
make[1]: Entering directory `/home/echo/download/uClinux-dist/include'
make[1]: Nothing to be done for `romfs'.
make[1]: Leaving directory `/home/echo/download/uClinux-dist/include'
make[1]: Entering directory `/home/echo/download/uClinux-dist/user'
for i in boa busybox cgi_generic dhcpcd-new ftp ftpd games inetd init ntp sash telnetd /home/echo/download/uClinux-dist/prop ; do
[ ! -d $i ] || make -C $i romfs || exit $? ;
done
make[2]: Entering directory `/home/echo/download/uClinux-dist/user/boa'
for i in src ; do make -C $i romfs || exit ; done
make[3]: Entering directory `/home/echo/download/uClinux-dist/user/boa/src'
romfs-inst.sh /bin/boa
cp: can't confirm ‘boa’: No such file or directory
make[3]: *** [romfs] error 1
make[3]: Leaving directory `/home/echo/download/uClinux-dist/user/boa/src'
make[2]: *** [romfs] error 2
make[2]: Leaving directory `/home/echo/download/uClinux-dist/user/boa'
make[1]: *** [romfs] error 2
make[1]: Leaving directory `/home/echo/download/uClinux-dist/user'
make: *** [romfs.subdirs] error 1
>make
CHK include/linux/version.h
CHK include/linux/utsrelease.h
CHK include/linux/compile.h
GEN usr/initramfs_data.cpio.gz
/home/echo/download/uClinux-dist/linux-2.6.x/scripts/gen_initramfs_list.sh: line 137: gawk:command not found
Unrecognized dir format '/init 777 1000 1000' line 42
make[2]: *** [usr/initramfs_data.cpio.gz] error 255
make[1]: *** [usr] error 2
make[1]: Leaving directory `/home/echo/download/uClinux-dist/linux-2.6.x'
make: *** [linux] error 1
>make
>make linux image
make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- -j1 -C linux-2.6.x zImage || exit 1
no emulation specific options.
make[1]: Entering directory `/home/echo/download/uClinux-dist/linux-2.6.x'
CHK include/nios2_system.h
perl -I/home/echo/download/uClinux-dist/linux-2.6.x/arch/nios2nommu/scripts /home/echo/download/uClinux-dist/linux-2.6.x/arch/nios2nommu/scripts/gen_nios2_system.h.pl cpu_0 sdram_0 cfi_flash_0 < /home/echo/download/HW/system_0.ptf > include/nios2_system.h.tmp; if [ -r include/nios2_system.h ] && cmp -s include/nios2_system.h include/nios2_system.h.tmp; then rm -f include/nios2_system.h.tmp; else echo &#39; UPD include/nios2_system.h&#39;; mv -f include/nios2_system.h.tmp include/nios2_system.h; fi
/home/echo/download/uClinux-dist/linux-2.6.x/scripts/gen_initramfs_list.sh: line 137: gawk&#65306;command not found
Unrecognized dir format &#39;/init 777 1000 1000&#39; line 42
make[1]: Leaving directory `/home/echo/download/uClinux-dist/linux-2.6.x&#39;
my ptf is from the wiki "system_0.ptf" and seclet Altera, nios2nommu, None Libc and default all settings, i did it step by step and i don&#39;t know why these errors happen and also don&#39;t know how to solve them.
so can any body help me?i will show great appreciation to you! thanks!
Check if you have the "gawk" command with,
which gawk
Or check if you have it in /usr/bin or /bin dir.
Which Linux distro do you use? have you installed devolopment packages?
If you are new to Linux, I would suggest CentOS 4.4.
--- Quote Start ---
originally posted by hippo@Apr 4 2007, 09:28 AM
check if you have the "gawk" command with,
which gawk
or check if you have it in /usr/bin or /bin dir.
which linux distro do you use? have you installed devolopment packages?
if you are new to linux, i would suggest centos 4.4.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22799)
--- quote end ---
--- Quote End ---
i run the command "gawk --help", the terminal shows"command not found", and i have checked that there was no "gawk" in both /bin and /usr/bin dir.
i use ubuntu6.1 linux .
just now i build kernel again, but run "make romfs" after running "make", and finally i got the zImage file ,but there were still many problems as follows(after i run "make linux image") :
Unrecognized dir format &#39;/bin/cp 777 1000 1000&#39; line 9
Unrecognized dir format &#39;/bin/dd 777 1000 1000&#39; line 10
Unrecognized dir format &#39;/bin/mount 777 1000 1000&#39; line 11
Unrecognized dir format &#39;/bin/netstat 777 1000 1000&#39; line 12
Unrecognized dir format &#39;/bin/ping 777 1000 1000&#39; line 13
Unrecognized dir format &#39;/bin/rm 777 1000 1000&#39; line 14
Unrecognized dir format &#39;/usr/bin/ftpget 777 1000 1000&#39; line 59
Unrecognized dir format &#39;/usr/bin/ftpput 777 1000 1000&#39; line 60
Unrecognized dir format &#39;/usr/bin/telnet 777 1000 1000&#39; line 61
Unrecognized dir format &#39;/usr/bin/wget 777 1000 1000&#39; line 62
Unrecognized dir format &#39;/init 777 1000 1000&#39; line 66
Unrecognized dir format &#39;/sbin/ifconfig 777 1000 1000&#39; line 68
Unrecognized dir format &#39;/sbin/insmod 777 1000 1000&#39; line 69
Unrecognized dir format &#39;/sbin/lsmod 777 1000 1000&#39; line 70
Unrecognized dir format &#39;/sbin/modprobe 777 1000 1000&#39; line 71
Unrecognized dir format &#39;/sbin/rmmod 777 1000 1000&#39; line 72
Unrecognized dir format &#39;/sbin/route 777 1000 1000&#39; line 73
You need gawk package, follow
https://help.ubuntu.com/6.10/ubuntu/desktopguide/c/apt.html (https://help.ubuntu.com/6.10/ubuntu/desktopguide/c/apt.html
If you are new to Linux, you should try CentOS 4.4 (but not 5.x) . Select the development tool package group, everything should be here.
--- Quote Start ---
originally posted by hippo@Apr 4 2007, 08:53 PM
you need gawk package, follow
if you are new to linux, you should try centos 4.4 (but not 5.x) . select the development tool package group, everything should be here.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22820)
--- quote end ---
--- Quote End ---
thanks, hippo. i have solved it! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/laugh.gif
--- Quote Start ---
which gawk
--- quote end ---
--- Quote End ---
I have it in /usr/bin dir,
but when i make romfs:
make[2]: Entering directory `/home/nios/download/uClinux-dist/user/boa&#39;
make[3]: Entering directory `/home/nios/download/uClinux-dist/user/boa/src&#39;
cp: stat‘boa’&#22833;&#36133;: &#27809;&#26377;&#37027;&#20010;&#25991;&#20214;&#25110;&#30446;&#24405;
make[3]: *** [romfs] &#38169;&#35823; 1
make[3]: Leaving directory `/home/nios/download/uClinux-dist/user/boa/src&#39;
make[2]: *** [romfs] &#38169;&#35823; 2
make[2]: Leaving directory `/home/nios/download/uClinux-dist/user/boa&#39;
make[1]: *** [romfs] &#38169;&#35823; 2
make[1]: Leaving directory `/home/nios/download/uClinux-dist/user&#39;
make: *** [romfs.subdirs] &#38169;&#35823; 1
