12748 Discussions
building NiosII system library
I run Quartus / NiosII IDE 6.0sp1.
When I build a system library in the NiosII IDE, all the files and directories in the associated Quartus project get their attributes set to READ_ONLY.
This is a pain in the butt, as I then have to manually change the attributes before I can do much with the project.
This problem has existed in my setup for some time, with eairlier versions of Altera tools - it's just that only recently I've figured out just when the problem occurs.
Has anyone else found this behaviour?
Is there a setting somewhere that I need to change?
Thanks in advance for any help with this.
I guess the last post wasn't quite clear...
the file locking behaviour only occurs when I build a NEW niosII system library using the wizard, not every time I compile/build the system library project.
