I run Quartus / NiosII IDE 6.0sp1. When I build a system library in the NiosII IDE, all the files and directories in the associated Quartus project get their attributes set to READ_ONLY. This is a pain in the butt, as I then have to manually change the attributes before I can do much with the project. This problem has existed in my setup for some time, with eairlier versions of Altera tools - it's just that only recently I've figured out just when the problem occurs. Has anyone else found this behaviour? Is there a setting somewhere that I need to change? Thanks in advance for any help with this.Link Copied
I guess the last post wasn't quite clear...
the file locking behaviour only occurs when I build a NEW niosII system library using the wizard, not every time I compile/build the system library project.
