12748 Discussions
c and cpp living together?
Hello forum,
I am working on a project using c and c++ code with eCos. I notice that eCos is written mainly in c++, but many other components in my system is written with c. This leads me to suspect that mixing c and c++ works OK if you know how. I have no trouble running an example project written in c, but when I start to incorporate cxx code files, things start to look bad.
Before someone says, 'post to the eCos forum', my question is more fundamental - how do you go about mixing c and cxx code in the context of gcc and the NiosII IDE?
Thanks in advance for any replies.
You can find much info from google.com.cn by using key words "mixing C and C++".
when using C++ style function in *.c file, you'll need to do a "C"-style function in the CPP file in order to to link it.
e.g. in CPP
extern "C" void CreateForm (void)
Form *frm = new Form();
then in main.c
extern void CreateForm (void);
int main ()
CreateForm ()
FYI.
David
Hi
Here i passed one link..from that you can get the idea and also solution for mixing c/c++ code in one file...
http://developers.sun.com/prodtech/cc/articles/mixing.html (http://developers.sun.com/prodtech/cc/articles/mixing.html
Go through this.
Definately you find the solution..
Let me know
slsnios
They can life together well.
Just make sure that all C++ is in a .cpp file.
The compiler uses the file extention to change its mode
