12748 Discussions
cal_uart(with fifo) + NIOSserial.c
As we know, we need uart with fifo to enchance the performance. So we got the cal_uart from Altera, which should tested by ourselves because it is not provided officially by altera.
Now we use cal_uart with 16 byte rx_fifo, 16 byte tx_fifo. We hope the fifo is transparent to linux driver, so the linux driver is still NIOSserial.c, which we changed nothing. But we got :
0. U-boot access the UART sucessful during rx, tx. We think U-boot using pool methed. Is it right?
1. tx data is successful
2. rx data is abnormal. After linux startup, linux will reboot immediately after we receive any data by cal_uart.
3. We try to debug NIOSserial.c using printk . Is it right way to debug in UART driver?
thank u in advance.
It will be very difficult to debug on the same serial console. You'd better use jtag as console, to test the new uart on some other port.
You can use printk() then.
I use the cal_UART instead of the UART,then generate cpu_name.ptf, compared with the old cpu_name.ptf, there is no the list information in the new cpu_name.ptf!
who can help me ?
1.
PORT_WIRING
PORT rxd
direction = "input";
width = "1";
Is_Enabled = "1";
PORT txd
direction = "output";
width = "1";
Is_Enabled = "1";
PORT cts_n
width = "1";
Is_Enabled = "0";
PORT rts_n
width = "1";
Is_Enabled = "0";
I can get
PORT rxd { direction = "input"; width = "1"; Is_Enabled = "1"; } PORT txd { direction = "output"; width = "1"; Is_Enabled = "1"; }
and rts_n, cts_n are depent to your setup during add cal_uart to NiosII in SOPCbuilder.
How about RXD and TXD?
We tested the cal_uart's irq signal is only active for 1 clock period so
I changed
<cal_uart>/uart_pm.pl:L1933:rx_char_ready to rx_not_empty
in order to
irq <= ... rx_not_empty ...
then it worked well.
Can anyone tell me how to obtain the CAL_UART design please?
* Edited* Got it now. many thanks
Hi all,
I am trying the cal_avalon_uart core, but I get some problems.
I tried to do as mountain8848 said :
change rx_char_ready to rx_not_empty at line 1933
But I still get communication problems with uClinux. I only receive chars after 64 bytes are in the FIFO (the FIFO is 64 bytes long). SO an interrupt is only generated when the fifo is completely full. The main problem is that after it worked once or twice (64 or 128 bytes received), uClinux crashes (no response on any console).
Did someone fix this ?
Thanks for help
Pierre-Olivier
We were able to get the cal_uart working fully only after modifying the verilog code.
It seems that it only supports polling mode cleanly.
When using interrupts, it doesn&#39;t generate them in a way that takes advantage of the fifo&#39;s.
We had to modify our verilog code so that interrupts were generated only when the fifo was 75% full for example.
This was done by changing the "qualified_irq" assignment.
Until we made the modifications, the cal_uart component didn&#39;t perform any different than the normal Altera_Avalon_Uart.
in n2cpu_nii5v1.pdf p45, It is said " By peripheral design, an IRQ bit is guaranteed to remain asserted until the processor explicitly responds to the peripheral."
If we did not changed anything with FIFO_UART(cal_uart), the irq is a pulse, which duty cycle is one period of the system clock.
So we change rx_char_ready to rx_not_empty at line 1933 so it will generate the IRQ properly----generate irp until NiosII deassert it by read all datas from FIFO.And we tested FIFO_UART with original NIOSserial.c
In our opinion:
1. FIFO_UART does generate IRQ as soon as it received one byte
2. During uClinux IRQ server, FIFO_UART dose receive any bytes to FIFO if there are datas in the RXD line ---- this is one of benefits of FIFO.
3. NIOSserial.c does receive all datas from FIFO_UART untill FIFO is empty and IRQ will deassert.
Then things happen again and again.
Like trk_golf said, It will be grate if the IRQ generates at 75% full of FIFO. But it should be add a Timer to tell the us there are datas in FIFO, which maybe never get 75% full of FIFO. We did not work out this method. Any helps about this will be appreciate!
PS: After change the SOPC components perl scripts file , you should regenerate NiosII in SOPC builder, recompile in Quartus, re-debug in uClinux.
Thanks for the replies,
So it acts like I expected, but I don&#39;t understand why uClinux crashes then.
When I cat the serial port (cat /dev/ttyS3), it works for around 128 chars, then linux crashes.
Is there any explanation to this ?
Pierre-Oliver
Kernel did crased before we modified the FIFO_UART HDL. Kernel started, recevied some datas , crashed and rebooted automaticlly.
You&#39;d better debug tty using JTAG as Console like hippo said. Post some debug information here. Although I am not good at SW, but so many other NIOSII GODs here, haha.
Hi trk_golf,
Is it possible for you to post the modifications to the Verilog to have the interrupts working correctly (I mean with better performance than the altera_avalon_uart, and no kernel crash) ?
Thanks in advance,
Best regards
Pierre-Olivier
I am struggling to use CAL_AVALON_UART with uClinux, but only get about 16 chars out before it falls in a heap. As Pierre-Olivier says, it would be wonderful if someone has figured out how to make this work, and could post details http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
Please send your UART testing c file to me , and I tested it what&#39;s happen.
other1999@163.com
Then I could post all things in details.
Dear smalllight,
I actually did not make any testing C file. All I did was a cat /dev/ttyS0 (set to 115200 bauds with stty). Then with minicom on my computer, I send about 5k of data (copy/paste in the minicom teminal). With that test it crashes quite fast.
Another test was typing some charcters one by one in the terminal. I did not get anything in the cat /dev/ttyS0 until 64 chars were received (64 is the FIFO length). It works 3 or 4 times, then the system crashes.
Thank you for taking some time for this.
Pierre-Olivier
Some more details :
I made some new tests with the cal_uart.
I don&#39;t get any more uClinux crash (don&#39;t know why...), but I still get the poor performances of altera_avalon_uart.
When I just do a "cat /dev/ttyS0 > /tmp/file &" (/tmp/file is on a ramfs), and that I send lots of characters (10k) from my computer, and that I read the size of /tmp/file, I can see it is not the right size, and that the size is different evrytime I try this. This is exactly what I had with the altera_avalon_uart, except that now I don&#39;t receive the "ttyS0 : xx characters overrun".
It seems to be normal because we don&#39;t take advantage of the FIFO.
Could you tell me how to change this ?
Thanks a lot,
Pierre-Olivier
I’m Mountain8848 from China(other1999@163.com), and I posted the last post using my colleague&#39;s account —smalllight by mistake.
However I received both of your email---- cetic and hootsmon.
To hootsmon:
I compare your NIOSSerial.c with original one, and find you modified it. I guess the reason of it:
After we use cal_uart, during *.ptf to nios2_system.h the cal_uart module is not regarded as a UART class, so nios2_system.h misses below codes:
/* Executing ...scripts/nios2_system.h/altera_avalon_uart.pm */# ifndef __ASSEMBLY__# include <asm/uart_struct.h># endif /* The default uart is always the first one found in the PTF file */# define nasys_printf_uart na_uart0
Maybe you modified NIOSSerial.c in order to compile successfully. I don’t know if it is the problem.
NOTICE:
1. I just chang uart to cal_uart with 16byte rx_fifo, 16byte tx_fifo, which should be modified to avoid irq error as:
<cal_uart>/uart_pm.pl:l1933:rx_char_ready to rx_not_empty; regenenate in sopc; recompile in quartus
2. cal_uart’s document was said cal_uart should transparent with software. SO nothing was changed in NIOSSerial.c/ NIOSSerial.h. and nios2_system.h , which was generated with uart ones
3. kernel menuconfig: enable UART driver and UART console
To cetic:
I tested cal_uart and uart in my custom board as your method. Cat /dev/ttyS0 > /tmp/file &
I sent about 30 chars to cal_uart and uart.
1. per 100ms per 30 chars both uarts lost chars
2. per 200 ms per 30 chars cal_uart is OK, while uart still lost chars
3. send 3KB file to them, if I send quickly both cat process will be terminated abnormal, however the kernel still work fine.
BTW, The size of /tmp/file is always smaller then the one of the send file. I am still a newbie in uClinux, I don’t know why.
Maybe you should send your datas one packets by one packets to let little Nios have a brake :-)
After you give the good news I am very interested to put FIFO_UART to "Post Your Own IP".
Hi mountain8848,
I am currently making some performance tests on the cal_uart. As you said, there is a (small) performance gain when using the cal_uart but it is not big. I will start modifying the HDL code of the uart to generate the interrupt when the FIFO is half full or 75% full, I will post the results here as soon as it is done.
Regarding the post of the files in the &#39;Post your own IP&#39; section, you should be careful of where the SOPC builder component comes from...do we have all rights on it ? From what I know it is not officially released and it comes from someone inside Altera. Maybe you know more than I do about it, but I would not dare positng it without the authorization of the initial author (that I don&#39;t know...).
Anyway, lots of thanks for your help,
Pierre-Olivier
Thank you very much! I learn much from you!
Best Regards!
FeiWu
Hi all,
here is some good news for those who want a better performance on UART, based on cal_uart.
I could achieve a 1MBytes transfer at 115200 bps with no errors when "cat /dev/ttyS0 > /tmp/file&" is the only user task I run (Nios2\s at 72MHz). I get ~1% error on 1MBytes transfer when running several daemons at the same time. I did it with a 64 bytes FIFO and I had the same performances with a 1024 bytes FIFO.
To do this I modified the VHDL file generated by cal_uart to change the rx irq conditions. The interrupt is requested when FIFO is 50% full or if bytes are present in buffer after a delay (so that even if FIFO never gets 50% full, bytes can be read).
I still have some questions about this :
- I don&#39;t know anything about the scripts that generate the VHDL from the SOPC builder .ptf file. Can someone tell me where I should add my code so that it is generated in the cal_uart component ? Is this in the em_uart.pl script ? Is there any documentation on how to use this kind of scripts ? For now I have to modify the VHDL file after generating the SOPC builder components, this is not very elegant (see below)...
- To adjust performance, I can play with 3 parameters : FIFO size, FIFO level to request IRQ (50% full, 75% full....) and the timer delay. I tried with 64 bytes FIFO, 50% full and 7ms delay.
Does anyone have an idea of the parameters commonly used in other FIFO&#39;ed uarts ?
If someone is interested, here is the small modifications to do to the uart_ext.vhd file generated when using a cal_uart at 115200 bauds, 8N1, RTSCTS enabled, baudrate divisor writeable, and a 64 bytes FIFO :
At line 1288,
replace
               signal tx_not_empty :  STD_LOGIC;                signal tx_not_full :  STD_LOGIC;                signal tx_overrun :  STD_LOGIC;                signal tx_used :  STD_LOGIC_VECTOR (5 DOWNTO 0);
by
               signal tx_not_empty :  STD_LOGIC;                signal tx_not_full :  STD_LOGIC;                signal tx_overrun :  STD_LOGIC;                signal tx_used :  STD_LOGIC_VECTOR (5 DOWNTO 0);                signal rx_counter : STD_LOGIC_VECTOR (18 DOWNTO 0);                signal rx_fifo_timeout : STD_LOGIC;
At line 1541,
replace
 qualified_irq <= ((((((((((ie_dcts AND dcts_status_bit)) OR ((ie_any_error AND any_error))) OR ((ie_tx_shift_empty AND tx_shift_empty))) OR ((ie_tx_overrun AND tx_overrun))) OR ((ie_rx_overrun AND rx_overrun))) OR ((ie_break_detect AND break_detect))) OR ((ie_framing_error AND framing_error))) OR ((ie_parity_error AND parity_error))) OR ((ie_rx_char_ready AND x_not_empty))) OR ((ie_tx_ready AND tx_not_full));
by
 qualified_irq <= ((((((((((ie_dcts AND dcts_status_bit)) OR ((ie_any_error AND any_error))) OR ((ie_tx_shift_empty AND tx_shift_empty))) OR ((ie_tx_overrun AND tx_overrun))) OR ((ie_rx_overrun AND rx_overrun))) OR ((ie_break_detect AND break_detect))) OR ((ie_framing_error AND framing_error))) OR ((ie_parity_error AND parity_error))) OR ((ie_rx_char_ready AND (rx_used(5) OR rx_fifo_timeout )))) OR ((ie_tx_ready AND tx_not_full));  process (clk, reset_n)  begin      if reset_n = &#39;0&#39; then          rx_fifo_timeout <= &#39;0&#39;;          rx_counter <= (others => &#39;0&#39;);      elsif clk&#39;event and clk = &#39;1&#39; then          if std_logic&#39;(clk_en) = &#39;1&#39; then              if rx_counter(18) = &#39;1&#39; then                  if rx_empty = &#39;1&#39; then                          rx_counter <= (others => &#39;0&#39;);                      rx_fifo_timeout <= &#39;0&#39;;                  else                      rx_fifo_timeout <= &#39;1&#39;;                  end if;              else                  rx_counter <= rx_counter + 1;                      rx_fifo_timeout <= &#39;0&#39;;              end if;          end if;      end if;  end process;
I hope someone can help me automate this :-)
Any comments or help welcome.
Pierre-Olivier
