12745 Discussions
can not write USM of max10 onchip flash
hi everyone, i meet some problems in max10 onchip flash UFM write and read
this is my code, it is only a test code, i want to test the write and read of UFM in debug mode.
# include "alt_types.h"# include "altera_avalon_pio_regs.h"# include "system.h"# include <stdio.h># include <unistd.h>
int main()
alt_u32 i=0;
alt_u32 flash_status_reg1=0;
alt_u32 flash_control_reg1=0;
alt_u32 flash_data_reg1=0;
alt_u16 j=0;
alt_u16 a=0;
while (1)
flash_status_reg1=IORD_32DIRECT(ONCHIP_FLASH_0_CSR_BASE,0x0); //read flash status it shows 0xfffffc00, which means the flash in idle, read
failed, write failed, erase failed, and all the sectors pretection bit is 0(no protection)
flash_data_reg1=IORD_32DIRECT(ONCHIP_FLASH_0_DATA_BASE,0x4000); //read UFM0's first 32bit, it shows 0xffffffff, (this may be right because i have erased the UFM0,UFM1 successful last time, )
failed, write failed, erase failed, and all the sectors pretection bit is 0(no protection), does this shows the data read failed? why?
flash_data_reg1=IORD_32DIRECT(ONCHIP_FLASH_0_DATA_BASE,0x4); //read UFM1's second 32bit, it shows 0xffffffff, (this may be right because i have erased the UFM0,UFM1 successful last time, )
flash_data_reg1=IORD_32DIRECT(ONCHIP_FLASH_0_DATA_BASE,0x8);//read UFM1's third 32bit, it shows 0xffffffff, (this may be right because i have erased the UFM0,UFM1 successful last time, )
flash_status_reg1=IORD_32DIRECT(ONCHIP_FLASH_0_CSR_BASE,0x0);//read flash status it shows 0xfffffc00, which means the flash in idle, read
flash_control_reg1=IORD_32DIRECT(ONCHIP_FLASH_0_CSR_BASE,0x4);//read flash control register it shows 0x3fffffff,
IOWR_32DIRECT(ONCHIP_FLASH_0_CSR_BASE,0x4,flash_control_reg1&0x3f7fffff); // write to flash control register, disable the write protection of UFM1
flash_control_reg1=IORD_32DIRECT(ONCHIP_FLASH_0_CSR_BASE,0x4); //read flash control register it shows 0x3f7fffff, so write to flash control register successful
IOWR_32DIRECT(ONCHIP_FLASH_0_DATA_BASE,0x0,0xab); // write to flash UFM1's first 32 bit ,
flash_status_reg1=IORD_32DIRECT(ONCHIP_FLASH_0_CSR_BASE,0x0); // check the status, it shows write failed or stuck in busy_write....
why this happen?is there any reference design about how to use the UFM?
thanks!
here's a reference design for UFM for MAX 10
https://cloud.altera.com/devstore/platform/14.0.2/putting-altera-max-series-in-hibernation-using-user-flash-memory-an547/
Also, which version of quartus are you using?
quartus 14.1
i have downloaded an547, i am trying to open it...
i have downloaded an547 many weeks before, i tried for many times, can not open the reference design
i install the reference design, but i can not find the quartus project files in the folder.
i have installed many reference designs, but i can not figure out this one.
by the way, i have seen the folder, the m10_int_flash_mem.qsys just have a flash, no nios processor.
i have read the max 10 user flash memory user guide.pdf, it do not tell me how to use the ufm in nios.
