? cfi-flash
When trying to use the NIOS IDE Flash Programmer on a custom board at USER, I get the message:
CFI- no flashtable at address 0x00000000
Programming aborts,
There is only a CFI flash on this board, no EPCS
The reset vector is pointing to ext-flash: 0x00000000
The configuration controller is set to operate on: USER 0xC0000000
Recovery 0xE0000000
As the instruction says: the flash base is to be 0x00000000
I put three flash sections in the SOPC:
Hardware_FPGA 0x00000000
USER 0xC0000000
Recovery 0xE0000000
Is there a communication between the NIOS Programmer and the config controller?
Or do I have to change my reset vector?
What do I have to change?
Thanks in advance.
andy
