Hello, im new in altera Nios II, im doing a Plamprint Identification system based on NIOS II, in my part is using nios ii to comparing reference data and input data.
We are using a TRDB_D5M digital camera and DE1 board for doing this project. The camera will capture a first picture and store in to the DE1 SDRAM. and so on the second picture. My friend will convert the two picture in to the binary digit and store in SDRAM or flash memory. i have to compare the the two binary digit to show is it same or not. After I did the SOPC builder in Quartus II, and then go to Nios II. Let said I had ref.txt file in SDRAM/flash memory, the content inside is 0000 0000 input.txt file in SDRAM, the content inside is 1111 1111 How do i use c programming in Nios II to implement this comparing data ??#include <stdio.h># include <unistd.h>
Int main()
int ref; //how do I call the file in the SDRAM or flash memory ??
int input;
While(1)
If ( ref != input )
Printf (“\n fail”);
else
Printf(“\n access “);
Return(0);
The SDRAM stores bytes, not files!
Talk to you collegue to find out what he is using to identify the separate images.- Mark as New
THANKS for your reply dsl..!
after we bought the TRDB_D5M digital camera, their have provide a verilog DHL code (.sof), after we programe this .sof using quartus II programmer into the DE1 board, the camera will capture the image after a button pressed, and the image will store to SDRAM. so is it possible to read the image using Nios II ?? using printf() will do ?
