sending packet like broadcast
Hello all,
is possible to send packets in uClinux like broadcast ?
I include code:
void udp_init_all(void)
// proved nastaveni ciloveho adresata soketoveho spojeni
host = gethostbyname("192.168.3.255"); // remote server
if(host==NULL)
{ printf("Address error.");
return;
// nastav struktury a cilovy port adresata
remoteServAddr.sin_family = host->h_addrtype;
memcpy((char *) &remoteServAddr.sin_addr.s_addr, host->h_addr_list[0], host->h_length);
// remoteServAddr.sin_port = htons(serverPort);
// navaz sitove spojeni
if ((socketDescriptor = socket(AF_INET, SOCK_DGRAM, 0)) < 0)
{ printf("Not able to create socket connection. \n");
return;
// exit(1);
serverAddress.sin_family = AF_INET;
serverAddress.sin_addr.s_addr = inet_addr(SRC_IP_ADR); //"192.168.3.238");
and sending code in main cycle:
// nastav adresu portu a posli udp paket
if (sendto(socketDescriptor, out_buf, len, 0,
(struct sockaddr *) &remoteServAddr, sizeof(remoteServAddr)) < 0)
{ printf("I am not able to send data to remote server.\n");
// close(socketDescriptor);
return;
// exit(1);
and code report me:
How can i send packets via broadcast ?
Where is error ?
Thank you for answer.
Jan Naceradsky, Czech Republic
Is sending IP packets as braoadcast not just using the broadcast address of the terwork you ar targeting (e.g. 192.168.2,255) ?
As routers don't forward broadcasts, I suppose not giving a network address will not work.
-Michael
Yes, i use broadcast address (in my case 192.168.3.255).
I found, that ping -c 5 192.168.3.255
send data, but without answer - 5 packets transmitting, 0 received.
May be i should use another function, not sendto(.....), in c source code.
Jan
I don't think that ping is bound to support broadcast.
A user protocol that does support broadcast is UDP. You need to write code for both ends.
-Michael
When i use:
the command tries to send 5 packets, every packets i can see in wireshark, but the uclinux doesnot get answer.
You mean, that i must to write program for pc (except program for uClinux) ?
(yes, i use the udp protocol)
Jan
Yes,
-Michael
--- Quote Start ---
When i use:
--- Quote End ---
I think that you hit the command 'ping -c 5 192.168.3.255' from your Nios uClinux system. If so, please consider who will reply the answer. Can your network reply to the 'ping broadcast' ? MS Windows OS ignores such broadcasts and Linux can ignore those by setting 'echo "1" > /proc/sys/net/ipv4/icmp_echo_ignore_broadcasts'.
Kazu
