12748 Discussions
controlling pio through web browser
i'm running boa in uclinux on DE2. i manage to control the led thru web browser using cgi with a troublesome user interface which user has to press an OK button to update the values to the board.
I would like to make the interface more powerful such tat, for eg, i can turn the led on or off using simple checkbox in the web interface; or display on user screen when a button or switch on the board is pressed...
how shud i approach tat? Pls advise. Thx.
ps. i read sth bout using java applet but i'm still trying to figure out how to make it work... here http://forum.niosforum.com/forum/index.php?showtopic=481 (http://forum.niosforum.com/forum/index.php?showtopic=481)
hello,could you tell me how to port boa to uclinux,thanks
--- Quote Start ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17864)
--- quote end ---
--- Quote End ---
i&#39;m doing exactly as the BuildrootGuide from hippo.
--- Quote Start ---
originally posted by jwlam+aug 26 2006, 11:10 am--><div class='quotetop'>quote (jwlam @ aug 26 2006, 11:10 am)</div>
--- quote start ---
<!--quotebegin-nwpu_zhf2004@Aug 26 2006, 09:39 PM
--- quote end ---
--- Quote End ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17868)</div>
[/b]
--- Quote End ---
Hi jwlam,
do you use the goahead websrver ? could you give me the website link? I want to do according to it.thanks
i&#39;m using boa. if u wan goahead, refer to http://forum.niosforum.com/forum/index.php?showtopic=3392 (http://forum.niosforum.com/forum/index.php?showtopic=3392
i tried it but it was not working as i can ping the board but cant access it with browser. haven tried to solve it.
--- Quote Start ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17875)
--- quote end ---
--- Quote End ---
hi jwlam,
I want to use boa ,not the goahead. could you tell me how to use the boa?
hello,
According to hippo,i&#39;m running boa in uclinux on DE2. this the web page
http://192.168.0.131/ (http://192.168.0.131/
4@D€:`:&#33869;?4??h?@B€;:&#33869;?:?4€€&€?4€€?? ;@€?4@#@:h4$`@554$`@55&#40403;?€&#23593;?@hD€&#58408;?@&#36501;D€€?@H??€&#36668;@4@&#30135;:?:???o!:?€?&#32907;&#33470;2€?8:??p€??€?%:??p€D€€@&#32907;?&#25794;:(&#57991;B:? A??&#58154;9€?:?H:?@:?8:h;:?&#21222;:&#33786;.@?€&#25933;?????&#32907;@?€?&#20769;8@?:??pD€€?&#38253;:??p?&#57966;€Bk&#32569;j€Dj $€&#20468;=p]k:??p??&#21245;€&#36271;?@.&€&#21245;? &#34292; ?€ ?:0TB:p@@&#20371;.!&#21178;} .€?€&#27213;.!E&#32430;:?:?8:??p?&@?€"?:??p@:0:?@L€&??0?&#26473;&#21157;6?€€?€0?€€??&#37226;A+&#25289;€?D?€&#23593;?(.!@:??€&#34416;.:?&#32408;[:?&#32408;[?" ?6?? ?,.!??/.!??2.!??5.!??7.!O @&#20268;} ??!&#32413; ?€&#32518;d??@&#20371;D.!&#32413; ??@&#20371;Q.!&#32413; ??X.!&#32413; ???&#20769;:? @??????(?@dn)"&#32907; @?!?€??€&#21129;:???:?€&#34416;:??€:?:???&#24705;&#33091;:?:?&#22401;&#36583;&€&#21184;€???&#32350;?€& €:?"&#32907;!? @?€?&#20769;?@?€?#&#25794;:(??&#29387;@in)€?&#34174;@&#26864;&6?:??@?€&#65281;&#38253;:?4€&#25597;1:p?:? ???€:&#30281;:&#33406; ?8:???????&#20324;@kn)&#21129;:???:?€&#34416;:???:?:???&#27070;&#33091;:?:?&#22401;&#36583;?&????€?€&#37327;0:??@&#65281;:?€???:&#22295;????€?@??:&#30332;:??&#32753; 4€??&#21145;?????p@:? ?p.!@? €?&#32907; &#20769;€&#58591;?
I thank there are some bugs in boa ,
could you help me !!!thanks
