custom hardware and driver
A project from piie. Good job!
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
hi Hippo,
first of all I want to thank you for the support you gave us. Great work!
Some fellows and me had to accomplish a project in our studies: The project was to create a custom piece of hardware which we had to add to the standard nios2 core and write a linux driver to drive this hardware under uClinux.
The output was a documentation about the whole thing. You might be interessted in reading this documentation or to publish it on your website/wiki. You can download the pdf here:
http://piie.net/files/nios2-uclinux-additional_hardware.pdf (http://piie.net/files/nios2-uclinux-additional_hardware.pdf
or the latex sources:
http://piie.net/files/nios2-uclinux-additi...hardware.tar.gz (http://piie.net/files/nios2-uclinux-additi...hardware.tar.gz
kind regards,
--peter[/b]
--- Quote End ---
But the nios wiki are not mine. They belong to everyone. You can edit and improve the wiki. Thank you.
