mount jffs2 error
Please see attachment
you'd better try them one by one.
try cfi first, and disable epcs.
the de2 has 4M cfi for later shippment. the de2_net has 1M cfi only. you need to update it in sopc builder and regenerate sof . you may see the thread of jay_1025, he had cfi jffs2 worked.
I have updated the sopcbuilder to 4M cfi and regenerated it , and how can I change the files altera.c and epcs_maps.c .Thanks !!
In Sopc Builder the cfi_flash_0 base:0x00000000 end 0x00300000
sdram base:0x00800000 end 0x00FFFFFFF
epca_controller base :0x00480800
THANKS
--- Quote Start ---
originally posted by andylei@Jun 18 2006, 12:30 PM
i have updated the sopcbuilder to 4m cfi and regenerated it , and how can i change the files altera.c and epcs_maps.c .thanks !!
  in sopc builder the cfi_flash_0 base:0x00000000  end 0x00300000
                              sdram      base:0x00800000 end  0x00fffffff
thanks
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16230)
--- quote end ---
--- Quote End ---
edit altera.c
static struct mtd_partition alteramap_partitions[] = {
.name = "romfs/jffs2",
.size = 0x400000,
.offset = 0x000000,
Rebuild kernel image from the start "make clean", "make linux_hwselect...."....
