hello,
i use QUARTUS 5.0 NIOS 5.0 i have a difficult software problem, i think something is writing undefined into memory, but i cannot find it (searching now for two days). in the main function i have the following... main() { int ctime=0; int ctimemax=0; while(1) { ... ... if(....) { ctimemax=1000; } else { ctimemax=5000; } if(ctime>ctimemax) { // at this point ctimemax is e.g. 0 or something undefined .... } ... } i have seen that the register fp (which is used to access ctimemax,stw r2,20(fp), is different from startup, when the error happens. the main problem is, that if i insert or renmove some code elsewhere, i cannot see the error again. one problem i have seen is that i made a fault with timer interrupts, but i don't know if this could cause the error. i had a# define # define ALARMTICKS(x) ((alt_ticks_per_second()*(x))/1000) DWORD alarm_spst_callback_10ms (void* context) { alarmflags|=ALARM_SP_10MS; if(led_txrx_time>0) { led_txrx_time--; PIO_CBI(PIO_LED_BASE,LED_TX_RX); } else { PIO_SBI(PIO_LED_BASE,LED_TX_RX); } if(dsptimeout) dsptimeout--; return ALARMTICKS(10); } this inserted a multiplication and division in the interrupt ... 0x00806874 <alarm_spst_callback_10ms+160>: call 0x80c524 <__mulsi3> 0x00806878 <alarm_spst_callback_10ms+164>: mov r4,r2 0x0080687c <alarm_spst_callback_10ms+168>: movi r5,1000 0x00806880 <alarm_spst_callback_10ms+172>: call 0x80c504 <__udivsi3> ... i changed this to get a constant for the return value, i cannnot see the error in the main loop again, but i think this was not the problem could the multiplication and division in the interrupt cause my problem ? any suggestions, how i can find this error ? i have seen that there is now "Run time stack checking", how does it works? thanksLink Copied
