dma_mapping.h stubs
I am trying to build a kernel with support for SL811, but I am having trouble defining the stubs for dma_mapping.h
I have checked the other threads in this forum, but there are no explicit examples of adding the dma stubs. Also, where should I add the stubs, include\nios2-nommu\dma_mapping.h ?
add the following to asm/dma_mapping.h:
static inline dma_addr_t dma_map_single(struct device *dev, void *cpu_addr, size_t size,        enum dma_data_direction dir) {     cache_push ((unsigned long)cpu_addr, size);     return virt_to_bus((unsigned long)cpu_addr); } /** * dma_unmap_single - unmap a single buffer previously mapped * @dev: valid struct device pointer, or NULL for ISA and EISA-like devices * @handle: DMA address of buffer * @size: size of buffer to map * @dir: DMA transfer direction * * Unmap a single streaming mode DMA translation.  The handle and size * must match what was provided in the previous dma_map_single() call. * All other usages are undefined. * * After this call, reads by the CPU to the buffer are guaranteed to see * whatever the device wrote there. */ static inline void dma_unmap_single(struct device *dev, dma_addr_t handle, size_t size,   enum dma_data_direction dir) {     cache_clear((unsigned long)bus_to_virt(handle), size); } /** * dma_map_sg - map a set of SG buffers for streaming mode DMA * @dev: valid struct device pointer, or NULL for ISA and EISA-like devices * @sg: list of buffers * @nents: number of buffers to map * @dir: DMA transfer direction * * Map a set of buffers described by scatterlist in streaming * mode for DMA.  This is the scatter-gather version of the * above dma_map_single interface.  Here the scatter gather list * elements are each tagged with the appropriate dma address * and length.  They are obtained via sg_dma_{address,length}(SG). * * NOTE: An implementation may be able to use a smaller number of *       DMA address/length pairs than there are SG table elements. *       (for example via virtual mapping capabilities) *       The routine returns the number of addr/length pairs actually *       used, at most nents. * * Device ownership issues as mentioned above for dma_map_single are * the same here. */ static inline int dma_map_sg(struct device *dev, struct scatterlist *sg, int nents,    enum dma_data_direction dir) {     int i;     for (i = 0; i < nents; i++, sg++) {  char *virt;  sg->dma_address = page_to_bus(sg->page) + sg->offset;  virt = page_address(sg->page) + sg->offset;  cache_push ((unsigned long)virt, sg->length);     }     return nents; } /** * dma_unmap_sg - unmap a set of SG buffers mapped by dma_map_sg * @dev: valid struct device pointer, or NULL for ISA and EISA-like devices * @sg: list of buffers * @nents: number of buffers to map * @dir: DMA transfer direction * * Unmap a set of streaming mode DMA translations. * Again, CPU read rules concerning calls here are the same as for * dma_unmap_single() above. */ static inline void dma_unmap_sg(struct device *dev, struct scatterlist *sg, int nents,      enum dma_data_direction dir) {     int i;     for (i = 0; i < nents; i++, sg++) {  char *virt;  virt = page_address(sg->page) + sg->offset;  cache_clear ((unsigned long)virt, sg->length);     } }
Is this going to be in the next release?
Thanks Wentau.
You will have to stay with me here. I am not too experienced with uClinux.
First off, when you suggest adding to asm/dma-mapping.h , does the asm somehow get expanded to asm-nios2nommu ? I guessed this might be the case, so I added the code to asm-nios2nommu/dma-mapping.h
Now I get a series of compilation warnings and errors, here&#39;s a snippet;
include2/asm/dma-mapping.h: In function `dma_map_single&#39;: include2/asm/dma-mapping.h:30: warning: implicit declaration of function `cache_push&#39; include2/asm/dma-mapping.h:31: warning: implicit declaration of function `virt_to_bus&#39; include2/asm/dma-mapping.h: In function `dma_unmap_single&#39;: include2/asm/dma-mapping.h:52: warning: implicit declaration of function `cache_clear&#39; include2/asm/dma-mapping.h:52: warning: implicit declaration of function `bus_to_virt&#39; include2/asm/dma-mapping.h: At top level: include2/asm/dma-mapping.h:79: warning: "struct scatterlist" declared inside parameter list include2/asm/dma-mapping.h:79: warning: its scope is only this definition or declaration,
Figuring that there must be an include file that I could reference for the undeclared functions, I did a grep on cache_clear, with no results.
How do I reference these undeclared functions, and structures?
Steve.
Yes clansdown, they will be in the next release.
Hi sfielding, yes I mean asm-nios2nommu/dma-mapping.h. Please add the following to the beginning of the file:
#include <asm/scatterlist.h># include <linux/mm.h># include <asm/io.h># include <asm/cacheflush.h>
You also need to add the following line to the file cacheflush.h in the same directory:
extern void cache_clear (unsigned long paddr, int len);
Thanks Wentao, the kernel now compiles just fine
