12748 Discussions
elf2flash and bootloader questions
I'm trying (so far in vain) to get RedBoot to run from flash. The ROMRAM startup version of RedBoot works fine when loaded into RAM via JTAG, but the ROM startup version of RedBoot doesn't run when programmed into flash. Other stand-alone programs seem to work fine when programmed in flash.
I see that the instructions mention some proprietary tool called elf2flash. It appears to be used instead of the standard Gnu binutils programs to generate an srec file. There also seems to be a "bootloader" srec file involved. I can find no detailed documentation on either elf2flash or the mysterious external bootloader which appears to be available only as an srec file.[list][*]What exactly does "elf2flash" do?[*]Why can't "objcopy" be used like all other normal eCos targets?[*]What is the external bootloader .srec file for?
[*]Why would a ROM-resident bootloader like RedBoot require a second bootloader?
[/list]
Hi grante,
You need to read the "Nios II Software Developer’s Handbook."
> * What exactly does "elf2flash" do?
See the handbook for details ... but basically what it says: it converts the elf to a flash file.
Very simply: it creates a record for each loadable section, throws in the bootloader if necessary,
and outputs the srec for the flash programmer.
> * Why can't "objcopy" be used like all other normal eCos targets?
It can -- just run it from the command line.
> * What is the external bootloader .srec file for?
Read chapter 4 in the handbook ... the section "Memory Usage."
> * Why would a ROM-resident bootloader like RedBoot require a second bootloader?
It doesn't -- you can use objcopy and bin2flash (if you want to use the flash programmer).
--Scott
Firstly, thanks for the resonse.
>Handbook."
I have. The copy I have is document number NII5V2-6.0.
What details? There's exactly one mention of elf2flash in the
handbook with a single phrase saying that it"converts an
.elf executable file to a .flash file for programming into
flash memory"
>file. Very simply: it creates a record for each loadable
>section, throws in the bootloader if necessary, and outputs the
Thanks, I had deduced that, but I was looking for exact
descriptions of what each parameter does, where the bootloader
is "thrown in", etc.
Then why was elf2flash written? Just for obsfucation value?
I did. And I just searched it again: the string "bootloader"
doesn't appear even once in the handbook. Chapter 4 is
about using the HIOS2 HAL system library. I'm not using the
HAL libarary, I'm using eCos.
Am I reading the wrong handbook?
If it's not required, why is program_flash adding it to the
srec file?
Grant,
Fair enough, my bad ... it's in the "Nios II Flash Programmer User Guide", not
the "Nios II Software Developer’s Handbook." My most sincere apologies.
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
elf2flash
The elf2flash utility takes a software executable file in .elf format, and
translates it to an S-record file suitable for programming into flash
memory.
elf2flash also inserts a boot copier into the flash file, if needed. elf2flash
inserts the boot copier code before the application code under the
following conditions:
&#9632; The CPU&#39;s reset address falls within the address range of the flash
memory being programmed.
&#9632; The executable code is linked to a memory location outside of the
flash memory being programmed.
If elf2flash inserts a boot copier, it also translates the application code .elf
file to a boot record for use by the boot copier. This boot record contains
all of the application code, but is not executable. After reset, the boot
copier reads the boot record from flash memory and copies the
application code to the correct linked address, and then branches to the
newly-copied application code.[/b]
--- Quote End ---
Sorry, I can&#39;t answer that ... but it&#39;s awful handy when using
the flash programmer ;-)
> doesn&#39;t appear even once in the handbook.
Yes, again, my apologies ... search for "boot copier" in the flash programmer&#39;s
manual.
--Scott
I forgot ... you can review the bootloader code -- look in:
$SOPC_KIT_NIOS2\components\altera_nios2\sdk\src\boot_loader_sources
--Scott
