error in niosII
hi
I turn a code under niosII .
I have this error I don't understant it
Pausing target processor: not responding.
Resetting and trying again: FAILED
Leaving target processor paused
can you please help me to resolve this error
regards
NiosII is not working.
Two possible causes:
- timing problems in Quartus compilation
In case, recompile the design after constraining clocks or reducing frequency
- Nios is disabled because you are using an unlicensed core
In this case you should not stop USB blaster connection after you have configured fpga
