I'm trying the multiprocessor design with 3 NIOS II, but when i run my design, i get this message with the first CPU, i think that this is related to the flash programming, can you tell me how to overcome this. Thanks a lot for your help. make -s all Compiling hello_world_multi.c... ../hello_world_multi.c:36:3: warning: no newline at end of file Linking hello_multi_cpu1.elf... Info: (hello_multi_cpu1.elf) 67 KBytes program size (code + initialized data). Info: 1980 KBytes free for stack + heap. Post-processing to create flash.flash Expected integer value for option 'reset' Value was: '' Using default value: -1 26-déc.-2005 12:53:20 - (GRAVE) elf2flash: Read error: File not found: / 26-déc.-2005 12:53:20 - (GRAVE) elf2flash: Error reading boot copier 26-déc.-2005 12:53:20 - (GRAVE) elf2flash: Error generating Flash file, exiting make: *** [flash.flash] Error 5 Build completedLink Copied
--- Quote Start --- originally posted by suemam@Dec 27 2005, 02:28 PM hi,
i'm trying the multiprocessor design with 3 nios ii, but when i run my design, i get this message with the first cpu, i think that this is related to the flash programming, can you tell me how to overcome this. thanks a lot for your help.
make -s all
compiling hello_world_multi.c...
linking hello_multi_cpu1.elf...
info: (hello_multi_cpu1.elf) 67 kbytes program size (code + initialized data).
info: 1980 kbytes free for stack + heap.
post-processing to create flash.flash
expected integer value for option 'reset'
value was: ''
using default value: -1
26-déc.-2005 12:53:20 - (grave) elf2flash: read error: file not found: /
26-déc.-2005 12:53:20 - (grave) elf2flash: error reading boot copier
26-déc.-2005 12:53:20 - (grave) elf2flash: error generating flash file, exiting
make: *** [flash.flash] error 5
build completed
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11808)
--- quote end ---
--- Quote End ---
Hi suemam,
Sorry about that. I did not get my comments in. I just started working with the tutorial. I am not sure of your problem but to rule out other stuff I would retarget my load for DDR or SDRAM and see what you get. Flash can be problematic at times. I am also having problems with this tutorial but I am able to compile. -Baycool- Mark as New
--- Quote Start --- originally posted by baycool+dec 29 2005, 06:34 pm--><div class='quotetop'>quote (baycool @ dec 29 2005, 06:34 pm)</div>
--- quote start ---
<!--quotebegin-suemam@Dec 27 2005, 02:28 PM hi,
make -s all
value was: ''
build completed
--- quote end ---
--- Quote End --- <div align='right'><{post_snapback}> (index.php?act=findpost&pid=11851)</div> [/b] --- Quote End ---
Hi Baycool,
Thanks a lot for your message, i'm going to send to you the name of the target board that i'm using. till now i didn't get solution of this matter, i continue to struggle with this error. thanks
Topic Options
