12745 Discussions
external 16Bit Slave, shared signals
I have problems connecting an external chip to NIOSII.
I used the standard design in SOPC Builder. The chip should work in 16bit
mode and should share all signals, except 'chipselect_n' with the external
SRAM IDT71V416 and the flash am29lv065d.
There was already a thread in this forum with the same problem, but no
helpfull answer.
In the standard design, the ext_flash has the description
"Flash Memory (Common Flash Interface)". There is another
"Legacy AMD 29LV065D Flash", which is installed in a different folder.
(see comonent Description).
I had a look in \components\altera_avalon_cfi_flash\class.ptf:
all signal except "write_n","select_n" are shared
I had a look in \components\altera_nios_dev_kit_stratix_edition_sram2\class.ptf:
all signal except "select_n" are shared
I started with the standard design.
I setup the Chip with Interface to User Logic:
CHIP NAME: HFCE1
Bus Interface Type: Avalon Register Slave
Port Name Width Direction Shared Type
reset 1 input reset
address 8 input yes address
write_n 1 input yes write_n
read_n 1 input yes read_n
data 16 inout yes data
chipselect_n 1 input chipselect_n
irq_n 1 output irq_n
be_n 2 input yes byteenable_n
In Quartus I got the following signals in Block diagram:
be_n_to_the sram_0[3..0] ???
chipselect_n_to_the_HFCE1_0
ext_ram_bus_address[22..0]
ext_ram_bus_byteenablen[1..0] ??
ext_ram_bus_data[31..0]
ext_ram_bus_readn
ext_ram_bus_writen
read_n_to_the_sram_0
reset_to_the_HFCE1_0
select_n_to_the_ext_flash
select_n_to_the_sram_0
write_n_to_the_ext_flash
write_n_to_the_sram_0
- which are the shared wires ?
- to which signal should i connect BE[0..1] of HFCE1
and BE[0..3] of SRAM ?
- what is the difference between
- ext_ram_bus_writen
- write_n_to_the_sram_0
- why there is no signal "read_n_to_the_ext_flash" in standard design.
in standard design "ext_ram_bus_readn" is connected to flash_OE
- what`s the difference between "ext_ram_bus_writen" and
"write_n_to_the_ext_flash"
- what`s the difference between "be_n_to_the sram_0[3..0]" and
"ext_ram_bus_byteenablen[1..0]"
Has anyone an working example for an external 16Bit Slave with shared signals
write_n,read_n,byteenable_n ???
thanks
Hi Fischer,
The signals that pop out into an SOPCB system can be decoded as follows (I am borrowing your list of signals):
be_n_to_the sram_0 ??? chipselect_n_to_the_HFCE1_0 ext_ram_bus_address ext_ram_bus_byteenablen ?? ext_ram_bus_data ext_ram_bus_readn ext_ram_bus_writen read_n_to_the_sram_0 reset_to_the_HFCE1_0 select_n_to_the_ext_flash select_n_to_the_sram_0 write_n_to_the_ext_flash write_n_to_the_sram_0
- Anything with "ext_ram_bus" in it is a shared signal for all interfaces on the tri-state bus. This is because ext_ram_bus is the name of your tri-state bridge.
- You need not hook up every signal that is shared (ext_ram_bus) to every pin on every chip; some will not be required (for example, if you're talking to a chip with read/write_n input, or no byte enables). This is device dependant.
- The remaining signals are not shared - they should have the name of a peripheral in the SOPCB system. For example, write_n_to_the_sram_0 means that you have a peripheral attached to your tri-state bridge named "sram_0"... and in its PTF file entry, there is a non-shared write line specified.
- I think the confusion here is because of that separate SRAM interface, sram_0.... just remember that any signals for such interface are not for your chip (the HFCD1)...conversely, any signal (chipselect) with the name HFCE1 is a non-shared pin going to your device as specified.
- If other signals, such as the byte enables, are shared, then the 2-bit BE whose name is "ext_ram_bus..." is what you would connect to your custom SRAM interface.
Please let us know if you need any additional assistance.
Thanks very much for your reply,
I´m a little bit confused about the fact, that a get a signal e.g.
read_n_to_the_sram_0, write_n_to_the_sram_0, even if these signals are marked
as 'shared' in the ptf file.
is it also true, that I need not hook up every 'none shared' signal to the specific chip,
if I can use a shared signal instead ?
I changed the setup of my HFCE1 chip to be_n[3..0], however it only need's two
signals be0_n and be1_n.
I did this to get a shared bus "ext_ram_bus_byteenablen[3..0].
So I will connect:
be_n_to_the sram_0[3..0] - ***not used***
chipselect_n_to_the_HFCE1_0 - HFCE1_CS_N
ext_ram_bus_address[22..0] - A[22..0] to FLASH,SRAM
and HFCE1 (A1 of bus to A0 of HFCE1, 16 Bit access)
ext_ram_bus_byteenablen[3..0] - BE[3..0] to SRAM (uses BE[3..0])
and HFCE1 (uses only BE[1..0])
ext_ram_bus_data[31..0] - D[31..0] to FLASH,SRAM,HFCE1
ext_ram_bus_readn - FLASH_OE_N, SRAM_OE_N and HFCE1_RD_N
ext_ram_bus_writen - SRAM_WE_N and HFCE1_WE_N
read_n_to_the_sram_0 - ***not used***
reset_to_the_HFCE1_0 - HFCE1_RESET
select_n_to_the_ext_flash - FLASH_CS_N
select_n_to_the_sram_0 - SRAM_CS_N
write_n_to_the_ext_flash - FLASH_WE_N
write_n_to_the_sram_0 - ***not used***
I connected "write_n_to_the_ext_flash" to FLASH_WE_N, because this signal is
marked as 'not shared' in the ptf file.
Is this correct ?
