flashprogrammer
Hi ,
I used m25p64 to store SOF & Software .
I found :
1>when I connect the SDRAM DQM[1:0] to NIOS , the FPGA and uClinux can work after power up from m25p64 !
2>when I fix initial the SDRAM DQM[1:0] to 2'b00 , the FPGA can work after power up from m25p64 ,but the uClinux can not work! but,it can work when used:
nios2-configure-sof $SOPC_KIT_NIOS2/examples/test.sof
nios2-download -g zImage
nios2-terminal
I do not understand why ?
I want reduce the SDRAM's DQM[1:0] and CKE!
thanks
arens
