frame reader and uClinux
Hi All,
Is it possible to modify the frame buffer layer in linux to use a frame reader hardware instead of a lcd_sgdma (used in the NEEK case) ?
If the answer is yes, any pointers would be helpful.
Dany
What is "a frame reader hardware" ?
Micheal,
a Frame Reader is an IP in the VIP library, it was introduced in quartus 9.0
http://www.alteraforum.com/forum/showthread.php?t=22319&highlight=frame+reader
and
http://www.alteraforum.com/forum/showthread.php?t=19710
might give you a better view.
